Thread Number: 10846
How do Electrolux Automatics work? |
Post# 117254 , Reply# 1   12/6/2010 at 11:34 (4,889 days old) by suckolux (Yuba City, CA)   |   | |
Post# 117256 , Reply# 2   12/6/2010 at 11:52 (4,889 days old) by scvacuumguy (SC)   |   | |
You are close- I may be slightly off as well, but this is what I have been told and what I have seen.
The dial regulates the pressure on the membrane in the automatic control. One hose goes to the bag chamber, one to the hose inlet, and the third hose goes over to the bellows that opens the chamber. |
Post# 117257 , Reply# 3   12/6/2010 at 11:53 (4,889 days old) by scvacuumguy (SC)   |   | |
Post# 117258 , Reply# 4   12/6/2010 at 11:55 (4,889 days old) by scvacuumguy (SC)   |   | |
Post# 117262 , Reply# 5   12/6/2010 at 12:27 (4,889 days old) by joe22 ()   |   | |
its magic. . . .electrolux magic |
Post# 117264 , Reply# 6   12/6/2010 at 12:40 (4,889 days old) by Collector2 (Moose Jaw, Sk)   |   | |
Its actually a very simple system. It works on a difference in suction pressure. When the pressure at the back of the bag compartment (aka - right off the motor) is the same as the pressure at the front (aka the hose connection) everything is ballanced. As the bag fills suction drops at the hose end and an imballance is created. When the imballance is sufficient enough it sucks down the bellows which activates, either the latch, releasing the front cover on older models. Which then, in turn, turns the machine off or, in newer models, it simply moves a switch which turns the machine off. The controll dial merely regulates the tension put on a diaphram spring which, in turn makes it harder or easier for the diaphram to operate (eg - requireing more or less of an imballance of suction to activate )
hope that makes sense. Doug |
Post# 117266 , Reply# 7   12/6/2010 at 12:47 (4,889 days old) by suckolux (Yuba City, CA)   |   | |
Post# 117284 , Reply# 9   12/6/2010 at 15:53 (4,889 days old) by scvacuumguy (SC)   |   | |
Post# 117290 , Reply# 10   12/6/2010 at 16:08 (4,889 days old) by suckolux (Yuba City, CA)   |   | |
Post# 117296 , Reply# 11   12/6/2010 at 16:23 (4,889 days old) by Crevicetool (GA )   |   | |
Hey kids, take a look at this thread done well over fifty years ago now...... CLICK HERE TO GO TO Crevicetool's LINK |
Post# 117304 , Reply# 13   12/6/2010 at 16:35 (4,889 days old) by suckolux (Yuba City, CA)   |   | |
Post# 117309 , Reply# 14   12/6/2010 at 16:58 (4,889 days old) by beerad (Beautiful Vancouver BC)   |   | |
400 vacuums?? Wow...Where do you keep them all? I am very curious. Would it be possible to post some piks of your collection? thanks, Brad. |
Post# 117336 , Reply# 15   12/6/2010 at 19:10 (4,888 days old) by scvacuumguy (SC)   |   | |
I've never had any clue what the cordwinder to bag chamber tube was from. I do know that it really doesn't change anything if you remove it- unless someone knows differently.
Beerad- I'll just send some pictures of the sheds...we are slowly going through all of the crap and trashing bits and pieces. Most of them are random 70s and 80s machines that we rob parts off of. Consider about 100 of those in-stock units for sale as well (I guess those shouldn't be considered "collection" machines) Crevicetool- Are you my Buckeye rep by any chance? |
Post# 117344 , Reply# 17   12/6/2010 at 20:54 (4,888 days old) by scvacuumguy (SC)   |   | |
That makes a lot of sense Hans. I guess it is a tiny, tiny stream of air. When we do a basic service and cleaning on a Lux for a customer, the motor gets blown out, but not removed- so we never re-connect the hose going to the cordwinder seeing as how that would take extra time to remove the motor, etc. I haven't had one come back with a cordwinder melting!
Post# 117351 , Reply# 18   12/6/2010 at 22:21 (4,888 days old) by Collector2 (Moose Jaw, Sk)   |   | |
Post# 117392 , Reply# 20   12/7/2010 at 08:34 (4,888 days old) by Collector2 (Moose Jaw, Sk)   |   | |
Post# 117409 , Reply# 21   12/7/2010 at 10:44 (4,888 days old) by scvacuumguy (SC)   |   | |
That makes perfect sense. I would imagine because of the compact size of the front dover on the Diplomat and for cheaper manufacturing reasons, they decided to disregard the original design. I wonder how much research and development it took to begin this system and perfect it as Electrolux did.
Just a tip for many people- before replacing the whole assembly if you have a door that keeps popping open, take a small wire and clean out the hose that terminates at the vacuum hose inlet. This has saved much time while doing a repair on one that keeps malfunctioning. |
Post# 117412 , Reply# 22   12/7/2010 at 11:22 (4,888 days old) by Klectrolux ()   |   | |
I've always wondered about Electrolux's R&D in general. Some of the designs, features, and way the machine is built is just pure genius. |
Post# 117430 , Reply# 23   12/7/2010 at 14:51 (4,888 days old) by suckolux (Yuba City, CA)   |   | |
