Thread Number: 10771
Central Vac. |
Post# 116483 , Reply# 2   11/30/2010 at 14:53 (4,895 days old) by luxg ()   |   | |
I have a Beam and love it! You won't be sorry you went with a central unit. Terry |
Post# 116487 , Reply# 3   11/30/2010 at 15:44 (4,895 days old) by klectrolux ()   |   | |
I've always been a fan of the older, brown machine VacuFlo systems. You can get a rebuilt older model for a good price. I did when we bought it in our old house. |
Post# 116498 , Reply# 4   11/30/2010 at 16:22 (4,895 days old) by joshdonnell ()   |   | |
i think the Aqua air is better then all of them it uses water |
Post# 116510 , Reply# 5   11/30/2010 at 17:07 (4,895 days old) by bimmer740 (Long Island, New York)   |   | |
Post# 116511 , Reply# 6   11/30/2010 at 17:25 (4,895 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Post# 116606 , Reply# 10   12/1/2010 at 18:08 (4,894 days old) by BrianKirbyClass (Eudora Kansas)   |   | |
Cody, keep in mind that there are several different kinds of Central Vacs and many different manufacturers. Some require large bags and filters that can be expensive. Others have a cyclonic action and require no bags and filters, you just dump the bucket a few times a year, depending on how much you use the system. The filter is permanent and self cleaning, and never needs replacement.(just shake it clean once in awhile, which is what i prefer, again everyone is different)
Some have the ability to suck up water and are hooked to a drain. It will really pay to do your homework when chosing a central system. There are also several types of wall and floor inlets from which to chose,,some are metal, some plastic. Some have the electric 2 prong direct connect hook up in the inlet, others do not, and require a pig tail electric cord, (if you are using an electric PN with the system) And as mentioned before, there are several types of hoses, attachments, and power heads, electric and turbine. I have wall to wall thick carpet,in a 3 bdroom ranch style home, but prefer a turbine power head. I also prefer not to have to buy and replace bags and filters constantly. I also prefer not to wrestle with an extra long hose all over the house, so, i chose a larger than required system,(for the square footage of my home) that covers at least 3000 square feet, with several inlets installed thruout the house, and a 20ft hose. Works great for me because my system (which is a Honeywell) is large enough to give excellent power to the turbine, and i dont have to fiddle with an electric connection or electric hose to the power head. The hoses with the on/off feature are very nice,,but not an absolute necessity. Check out the website for MD Manufacturing,,they have several videos explaning in detail the differences and features of the different systems,hoses and attachments. Also, E-Bay has good deals on hoses and systems too. MD and many people like the bag systems,,i prefer the cyclonic. The newer cyclonic models have a small window in collection bucket so you can easily see how full it is,,which is a nice feature. Some central systems have venting for outside the home, others have filters for the exhaust right at the machine, and thats what i have,,which works great for me. I also have 2 vac pans installed with my system, which makes sweeping up a breeze,,very handy. ALso if you have a garage, having an extra inlet out there is great for vacuuming out the car, or garage. Most central vacs have an inlet directly on the machine itself, so if the unit is installed in the garage, your all set there. Some people prefer to install the power unit in their basement, or closet away from the living area. One of my friends has all brass inlets installed in the floors of his house,with the power unit in the basement. The brass inlets are very impressive looking! So, everyone is different of course, you just have to check out all the features and options avalible of which there are many! Hope this helps. |
Post# 116651 , Reply# 11   12/2/2010 at 00:56 (4,894 days old) by bimmer740 (Long Island, New York)   |   | |
I must add to what Brian said above, there are so many different units out there and you really need to check them all out according to what your needs are. Like Brian, I too prefer a bagless cyclonic unit, hence why I chose a VacuFlo. The bin to my unit is slightly smoked in appearance but allows you to see how much dirt is in the bucket at all times so it takes the guess work out of when to empty the unit. I love Electrolux (Aerus) and had originally been dead set on getting a CentraLux, but after seeing the moster sized filter that they have inside them I decided against it. The amount of filth that could be caught inside that filter and choke the airflow, along with the thought of having to clean/wash it, was more than I wanted to deal with. The VacuFlo has a metal screen inside the unit which you must brush out or vacuum out when you empty the canister (I clean the screen when its half full). It takes me less than 5 minutes to unplug the unit, take off the container, vacuum it out with the Electrolux, and replace the dirt bin. Other than dumping the container, thats all the maintenance that my unit requires. Another feature that drew me to choosing a VacuFlo is that its vented outside the house. Whatever isnt captured in the bin is then sent outside of my house with the exhaust air. It really removes 100% of what you vacuum up into it, which was exactly why I wanted a central vacuum in the first place. Plus their is no smell that is emitted back into my basement and no after filter or HEPA filter to replace.
I also have direct connect inlets which were a must for me. I have a 30 foot direct connect hose along with the 35 foot low voltage VacuFlo TurboGrip hose kit. One nice feature of having direct connect inlets is you can pair your system with any power nozzle that uses a standard 2 prong connection and standard sized button lock wands. I have a Lindhaus Stealth nozzle but almost always use a Eureka Express PN when using the electric hose. The TurboCat Zoom is a good low profile turbo nozzle that does an adequte job on low pile carpeting, but I dont think it can really be compared to the power of an electric power nozzle. The TurboCat can choke some of the suction and airflow from the system so that it can run, where as the electric PN has its own motor to power the brush roll. Whatever sytem you decide to purchase, I would advise buying one larger than what is recommened for the size of your house. We discussed this several months ago and it really makes a difference in power and is especially important if you plan on solely using an air powered nozzle. Best of luck and happy vacuuming! ~Steven |
Post# 116687 , Reply# 12   12/2/2010 at 13:55 (4,893 days old) by vacman117 (Chicago, IL)   |   | |
and I really do love it! It has very good suction and comes with a very nice set of tools! We got the 90's style power nozzle, so it really is a great deep cleaner! Ours also came with a very nice straight suction tool, telescopic metal wand, two metal wands, long crevice tool, upholestry tool with removable brushes, and a dusting brush! We also got the garage tools which comes with a long crush proof hose, and TONS of attachments for car and floor cleaing!
Post# 116733 , Reply# 14   12/2/2010 at 21:59 (4,893 days old) by luxg ()   |   | |
Let us know what you decide Cody, I don't think you will be disappointed if you go with the Beam. Terry |
Post# 116737 , Reply# 15   12/2/2010 at 22:33 (4,893 days old) by cleaningbuff (Quincy, IL)   |   | |
Post# 116739 , Reply# 16   12/2/2010 at 23:26 (4,893 days old) by bimmer740 (Long Island, New York)   |   | |
Cody,
Beam is part of Electrolux from Europe (the red canister vacuums), not the Electrolux which is now Aerus. Aerus is the company that makes the Electrolux vacuums that we have always associated the name with in America, makers of the metal bodied tank canisters. I wasnt exactly sure what you meant when you said you always liked Electrolux, and was thinking you're referring to Aerus. Wanted to make sure you knew they werent related, just incase you didnt already know. If you did, then sorry for posting this. The Aqua Air does sound like its a pretty awesome machine, but its expensive. I cant imagine what would happen should there ever be a clog in the pipes when using it for wet pick up. It would probably make quite an expensive mess! |
Post# 117277 , Reply# 17   12/6/2010 at 14:52 (4,889 days old) by codyf ()   |   | |
ONE MORE QUESTION, CAN TWO HOSES BE IN USE AT THE SAME TIME? IE. DAN VACUUMING CAR'S AND ME CLEANING FLOORS IN HOUSE? |
Post# 117311 , Reply# 18   12/6/2010 at 17:05 (4,889 days old) by bagintheback (Flagstaff, Arizona)   |   | |
