Thread Number: 10683
Odd spots and squeaky motor |
Post# 115458 , Reply# 1   11/21/2010 at 20:30 (4,904 days old) by scvacuumguy (SC)   |   | |
Pop rivet a new 8mm bearing into the diplomat or either grease the one already in the machine. That will take care of the squeal at the end of the cycle.
On the Super J, it sounds like you have stains on the actual plastic. Some stains are very stubborn and will not come off. Without a picture, I doubt anyone would be able to help you out with a possible solution with that. |
Post# 115472 , Reply# 2   11/21/2010 at 21:25 (4,904 days old) by elux89 ()   |   | |
The sleeve bearing could also be getting a little on the dry side considering the vintage of the Super J. Pop the end cap off and lube the pad. Chris also gave you some good advice regarding the other bearing. |
Post# 115482 , Reply# 3   11/21/2010 at 21:45 (4,904 days old) by klectrolux ()   |   | |
What kinda lube would you suggest? Would sewing machine oil seem to do the trick? Id did the trick with the bearings on the brush roll on the AP280 and PN5 I have. Thanks for your help? |
Post# 115489 , Reply# 4   11/21/2010 at 22:16 (4,904 days old) by scvacuumguy (SC)   |   | |
Post# 115506 , Reply# 6   11/22/2010 at 00:12 (4,904 days old) by suckolux (Yuba City, CA)   |   | |
