Thread Number: 10510
Classic 3 belt lifter |
Post# 113670 , Reply# 2   11/6/2010 at 11:10 (4,920 days old) by a007kirbyman (--->> Originally My Mom <<--- (now Wisconsin))   |   | |
Hello James.
The lens' that are on the Classic III (2CB) & the Tradition (3CB) are often melted due to the heat. The pulley does NOT ever touch the lens, & yet the heat is intense enough to actually melt them. This will happen quicker & more so, if people do not change the belt often enough. Cheers & hagwknd all, Bill |
Post# 113682 , Reply# 3   11/6/2010 at 14:25 (4,920 days old) by sanimatic ()   |   | |
How often should you change a Kirby belt? They never seem to go bad. |
Post# 113979 , Reply# 4   11/7/2010 at 23:27 (4,918 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 114055 , Reply# 5   11/8/2010 at 16:51 (4,918 days old) by Briankirbyclass (Eudora Kansas)   |   | |
Ben, when i was selling for Kirby (Tradition - Legend days), they recommended as a general rule, the belt to the Rug Nozzle be changed at every 3d bag change. Of course it all depends on how much use the machine gets.
Starting with the Heritage 2, the little green indicator light will tell you when your belt is slipping or stretched, and needs replacing. None of the Kirbys before the HD2 had this feature, of course. I use my Classic Omega as a daily driver,sometimes using it several times a day ( i use it in my daily business) ,so i put on a new belt every 3 months or so. Brian W. |
Post# 114061 , Reply# 6   11/8/2010 at 17:11 (4,918 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 114078 , Reply# 7   11/8/2010 at 18:31 (4,918 days old) by a007kirbyman (--->> Originally My Mom <<--- (now Wisconsin))   |   | |
Hello Chris & Ben.
If using the knurled belts, I usually encourage changing them twice a year if you're an average 'vacuumer.' If you're still using (for nostalgia & originality) the older rubber (gray) belts, then more frequently. (In fact, this is the perfect time to kind of form the [new] habit... "change the clocks, change the batteries & change the belt [at least on a Kirby]" Changing belts is one of the simplest, most needed 'fixes' of a Kirby; & yet, the most often neglected maintenence. It makes such a world of difference in cleaning. If you're using the knurled belts, at 99 cents ($.99), it's NOT like I'm gonna retire because you bought a few belts. Woohoo!!! ~~lol~~ Quite often I tell a customer when they call with a concern, that they probably don't 'need me,' all they need to do is check & replace the belt. Often the response I get is: "Oh noooo, I checked the belt, it's fine; there must be something else wrong with it. I'll bring it in to you." Then they bring their Kirby in, I pull out the brushroll from the nozzle, & 'SHOW THEM' & 'EXPLAIN TO THEM' why the old belt is bad; & they almost always say, "I thought it was ok, because it's not broken." ~~lol~~ Whether you are mechanically inclined or not, most people will relate to this example. I proceed to ask: "If the belt(s) under the hood of your car (serpentine or "V") were stretched out & slipping, what would probably happen?" [Whether they answer or not, I continue, or agree with them if they are correct.] "You're vehicle is probably going to overheat & maybe do some motor damage. With the Kirby you're not going to hurt the machine; however, you are hurting your carpeting, etc. because the brushroll is NOT maintaining the proper speed." Then I show them an 'old' or stretched belt next to a new one. And they usually say, "Wow, now that makes sense!" I attempted to hold two (2) belts 'stacked' on top of each other to illustrate the 'stretching' of the belt. [I think you already know it, but the larger one is the bad one. ~~lol~~] It's tricky holding the belts & taking the picture so it's not blurry. ~~lol~~ I hope this helps. Cheers & hagn all, Bill Ps: Ben, changing the belt with NOT guarantee, not melting of the belt lifter lens. There can be other reasons the motor gets 'extremely' hot; if it does, this heat will conduct thru & out to the pulley. More likely with the aluminum fans I would think. |
