Thread Number: 7633
How do i service a hoover convertibles top bearing |
Post# 84165   11/16/2009 at 16:51 (5,268 days old) by thevacuumman (Borger, TX)   |   | |
because i forgot how to |
Post# 84194 , Reply# 2   11/16/2009 at 22:39 (5,268 days old) by hoovercelebrity (Germany)   |   | |
I was told to never oil those bearings! Just replace it. They're still available. Hoover part number 42939002. ~Fred |
Post# 84197 , Reply# 3   11/17/2009 at 01:51 (5,268 days old) by seamusuk (Dover Kent UK)   |   | |
According to all the Hoover Service info ive seen the top bearing in Seniors/Convertibles(also the rear bearing in Juniors/Larks) is self lubricating and MUST NOT be greased/oiled.......... Seamus |
Post# 84225 , Reply# 7   11/17/2009 at 18:33 (5,267 days old) by hoovercelebrity (Germany)   |   | |
I'm talking about greasing the LOWER motor bearing. We've established that the upper bearing shouldn't be greased OR oiled. ~F |
Post# 84276 , Reply# 9   11/19/2009 at 00:05 (5,266 days old) by collector2 (Moose Jaw, Sk)   |   | |
LOL - The lower (fan side) bearing is a Bearing and, as such can be greased with bearing grease. The upper is not an actual bearing. Its call a BUSHING and requires 3 in 1 oil. Generally bushings have a packing around them which holds oil to perpetually lubricate the bushing. Over time this drys out. The procedure which Mike describes above is the proper way of lubricating them as long as the bushing is still in good shape (they can be deformed through heat and friction if run dry). The same procedure is used for the old Canadian Electrolux motors (80 and AP series) as they had the same bearing / bushing configuration.
Post# 84317 , Reply# 10   11/19/2009 at 18:02 (5,265 days old) by marukap (Saint Louis, MO)   |   | |
OK, then why do ALL of these bushings say in plain English "DO NOT LUBRICATE"???? |
Post# 84364 , Reply# 13   11/20/2009 at 13:56 (5,264 days old) by electroluxxxx (……)   |   | |
umm I used bearing grease on the top bearing of my Hoover 1020 was that a mistake? |
Post# 84419 , Reply# 15   11/21/2009 at 09:23 (5,263 days old) by extraditgitzz ()   |   | |
Point well taken. I hate the plastic bag in the jacket. |
