Thread Number: 43808
Kirby 1CR armature/shaft moves horizontally |
Post# 457073   9/27/2022 at 07:07 (570 days old) by superocd (PNW US)   |   | |
If you pull on the shaft the cooling fan behind the bearing plate touches the bearing plate. Bearings are new. What gives? |
Post# 457093 , Reply# 1   9/27/2022 at 17:48 (570 days old) by texaskirbyguy (Plano, TX)   |   | |
Which bearing part numbers did you use? Which direction were the bearings installed? The bearings in this model have a correct way to install and this is the last model like that. |
Post# 457100 , Reply# 3   9/27/2022 at 21:30 (570 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
