Thread Number: 43768
Aerus Lux 5500 Chord will ONLY retract (no stops) |
[Down to Last] | ![]() |
Post# 456758 , Reply# 2   9/14/2022 at 15:36 by electrolux137 ![]() |
![]() 2
Post# 456764 , Reply# 3   9/14/2022 at 17:42 by Blackheart (North Dakota)   |   | |
![]() 1
The cord winders on most lux machines are quite simple. The mechanism that locks the winder is a little L shaped metal piece. it falls into a gap around a track which locks it. I'm guessing that your piece is either not falling into the gap or perhaps broke off the winder. It may just need a little lubrication. Unfortunately i'm better at doing these tasks than I am describing it.
Post# 456765 , Reply# 4   9/14/2022 at 21:41 by kirbylux77 (London, Ontario, Canada)   |   | |
Beatrice, Blackheart is probably correct in his assessment as to why your cord rewinder has failed. It most likely will require complete replacement - repairing cord rewinders, in general, is a very tricky task to do, and easy to injure yourself.
Take it into your local Aerus Electrolux dealer and have them change it. One caution I will give though - DO NOT take it to just any ordinary vac shop that does repairs! Aerus Electrolux canisters are easy enough to repair, but the aftermarket parts most shops can obtain are NOT the same quality as the genuine parts that Aerus Electrolux uses. It's especially noticeable in things like the quality of aftermarket electric hoses vs genuine electric hoses. Better to have the repair done right the first time :). Rob |
Post# 456776 , Reply# 5   9/15/2022 at 07:04 by Kloveland (Tulsa)   |   | |
Post# 456794 , Reply# 7   9/15/2022 at 18:33 by kirbylux77 (London, Ontario, Canada)   |   | |
If you are going to cut off the cord, just pull out the cord from the cord rewinder as far as you can and cut it off. Yes, those springs can indeed be rather tricky to deal with - hence the reason many shops won't even bother trying to repair a cord rewinder anymore.
Good luck with the repairs, and hopefully the aftermarket cord rewinder will last for you if you're careful. Just note, the plastic body can be a pain to get everything lined up perfectly when reassembling, so give yourself lots of time and be patient. Rob |
Post# 456805 , Reply# 9   9/16/2022 at 08:30 by kloveland (Tulsa)   |   | |
![]() Beatrice,
CLICK HERE TO GO TO kloveland's LINK |
