Thread Number: 43764
Circa 1915 Birtman "The Republic" |
Post# 456733   9/13/2022 at 15:12 (589 days old) by Hoover300 (Kentucky)   |   | |
A fellow collector picked this up for me at a certain store that I am sure a few of you are familiar with, and shipped it to me. I did pay an arm and a leg to get it, but worth it for something as rare as this. The bag has one small repair at the bottom, and no holes. The original cord is in very good shape, the 2 taped spots were rid of the old hardened cloth tape and redone in a more flexible electric tape. The original metal body inline switch has been gutted a long time ago but the shell is on the cord and shall stay there. A new inline switch will be fitted in its place. The original motor tag was missing so I added one from a similar, for parts motor from the same company. The handle can be removed, a small handle screwed onto the side, and the bag can latch on the box where the cord comes out in order to be turned into a primitive handheld. There is a brush bar controlled by a lever on the bottom, but the bristles are nearly gone. It sits on 3 small wood wheels, the rear one with a height adjuster knob.
Sadly the commutator is shorting out between 2 or 3 of the bars, causing it to run slowly and arc quite a lot. The rotor does seem similar to one from a sleeve bearing Bee Vac, I will attempt a swap tomorrow. As far as I know, this is the only one. If anyone else has one, please post pics! I'd love to see! |
Post# 456743 , Reply# 1   9/13/2022 at 20:09 (589 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 456747 , Reply# 2   9/13/2022 at 20:47 (589 days old) by royalsuper (france )   |   | |
Post# 456761 , Reply# 3   9/14/2022 at 16:41 (588 days old) by Hoover300 (Kentucky)   |   | |
I found that a Bee Vac G rotor is very similar, but with a longer end. So after many tweaks and modifications, I got it to work! Little to no arcing at all!
Post# 456762 , Reply# 4   9/14/2022 at 16:54 (588 days old) by Hoover300 (Kentucky)   |   | |
The only info I can find on this. The ad dates to 1915, yet the patent was applied for in 1916. Either the date for the ad is wrong, or they started production before applying for the patent.
Post# 456763 , Reply# 5   9/14/2022 at 17:15 (588 days old) by royalsuper (france )   |   | |
Post# 456778 , Reply# 7   9/15/2022 at 08:27 (587 days old) by bikerray (Middle Earth)   |   | |
Post# 456808 , Reply# 8   9/16/2022 at 12:48 (586 days old) by royalsuper (france )   |   | |
Kieran, I found this photo which comes from the stark's museum ,the vacuum cleaner seems to have been manufactured in 1915.is it the same manufacturer as yours ?
Post# 456810 , Reply# 9   9/16/2022 at 13:45 (586 days old) by Hoover300 (Kentucky)   |   | |
Wow...........
I've looked everywhere for a pic of that in Stark's old museum. The other aluminum vac behind it is 1 of a kind but I would pay a LOT for either of those. That is a Bee Model D. I own the modified motor to one. Same manufacturer but the motors are entirely different inside.
Post# 456813 , Reply# 10   9/16/2022 at 14:02 (586 days old) by Hoover300 (Kentucky)   |   | |
Oil wicks - Sorta. There are oiling holes on both bearings, but unsure if they have wicks.
Positioning - It is near impossible to push on any non-looped carpeting due to the low clearance and placement of the handle. I can't imagine how bad it was when the brush had bristles. Getting in corners is a paaaain lol I wonder if the brush strip was partially for safety, as much like my Brilliant, the fan is very close to the ground. However, unlike the Brilliant, the strip prevents fingers from being pushed into the fan. |
Post# 456814 , Reply# 11   9/16/2022 at 14:04 (586 days old) by Hoover300 (Kentucky)   |   | |
Back to the Bee D - the Grand Rapids Public Museum has one too. But theirs has an updated bag connection, a spot for a little lint roller in the head, and a cap on the front for a small hose.
Post# 456815 , Reply# 12   9/16/2022 at 14:20 (586 days old) by royalsuper (france )   |   | |
Post# 456816 , Reply# 13   9/16/2022 at 14:23 (586 days old) by Hoover300 (Kentucky)   |   | |
Post# 456817 , Reply# 14   9/16/2022 at 14:36 (586 days old) by royalsuper (france )   |   | |
