Thread Number: 43368
Agitator bearings for my Hoover U4363-045 |
Post# 453061 , Reply# 2   5/26/2022 at 22:22 (693 days old) by Paul (USA)   |   | |
Sorry - I've got Eureka on my mind regarding the brush rollss, but you get the idea of what type of info may be needed. |
Post# 453068 , Reply# 4   5/27/2022 at 08:52 (693 days old) by kloveland (Tulsa)   |   | |
Post# 454201 , Reply# 6   6/29/2022 at 00:11 (660 days old) by Durango159 (State College, PA)   |   | |
Hoover used that bearing in just about every brush roll of uprights and canisters from 1970s to mid 2000s. The true Hoover brush rolls had those bearings. Once TTI took over then brush rolls started getting made by CWP and it all changed and many parts went away.
Don't get confused by early versions of that bearing which used a white colored plastic top, the fit is the same. You can remove the plastic top, clean and then repack with grease. The best method of course is to use a Hoover grease gun if you have access or know a Vac Shop that has one. |
