Thread Number: 43271
Help! Rainbow e2 Gold leaking water |
[Down to Last] | ![]() |
Post# 452253 , Reply# 1   5/3/2022 at 10:23 (272 days old) by dysonman1 (the county)   |   | |
You should be using cold water only. The water fill line is to the top of the bubble in the bottom center of the basin. If the water is even a little warm, some will evaporate when the machine starts up, resulting in water drops in the exhaust.
Be sure to run the machine on HI speed with the hose attached. LO speed can be used without the hose attached to clean or scent the room air. And always use the machine with a clean HEPA filter on the exhaust. |
Post# 452273 , Reply# 2   5/3/2022 at 21:16 (272 days old) by mark40511 (Lexington, KY)   |   | |
Also, the blinking red light is normal. I have this machine. I will say this...if you got that second hand...I'd have it serviced...as in taken fully apart and cleaned inside and out...You can go about 1/2 inch over the fill line and yes..cold water only. If you're already doing all these things and water is still getting sucked out the back...something definitely wrong.
Post# 452283 , Reply# 4   5/4/2022 at 07:59 (271 days old) by vacman117 (Chicago, IL)   |   | |
