Thread Number: 43251
Rusty Hoover Armature Stuck |
Post# 452033   4/26/2022 at 10:24 (730 days old) by VacsofProsper (TX)   |   | |
Yesterday I received a package that contains some vacuum parts from 2011Hoover700, a friend of mine, and I got a Hoover Dial a matic hose with the suction control, along with a Hoover convertible motor assembly and a Hoover Elites motor for my white caddy vac that I accidentally messed up a couple weeks ago. I was excited to get the motor but I wanted to fix it up due to the fact it was a bit rusty and I'm trying to get the armature out to restore it a bit but it's stuck in the bearing. I've been using a hammer along with a pin and not having to damage the armature screw with the hammer alone. Anyone else had this problem before?
Post# 452034 , Reply# 1   4/26/2022 at 10:37 (730 days old) by bnsd60m9200 (Akron OH)   |   | |
Post# 452035 , Reply# 2   4/26/2022 at 10:40 (730 days old) by VacsofProsper (TX)   |   | |
Post# 452053 , Reply# 3   4/26/2022 at 15:50 (729 days old) by 2011hoover700 (owosso michigan)   |   | |
Post# 452055 , Reply# 4   4/26/2022 at 17:52 (729 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
bnsd60m9200 - He did not in any way state he was going to power the motor up like this. He is trying to dismantle the motor to clean it up.
For getting the bearing off the hub, you will need something that will dissolve the rust from the shaft to free the part and a lot of patience with a bearing puller. Might try brake parts cleaner (but dont get that on the motor windings and be sure to clean up because it leaves a slight film) For cleaning the rust and grime off the motor, some steel wool (on the winding block/heatsink only) and CRC Electric Parts Cleaner should do the trick at getting most of the rust off. There is also WD-40 Specialist Electrical Contact Cleaner that you might try too. |
Post# 452069 , Reply# 5   4/27/2022 at 08:09 (729 days old) by VacsofProsper (TX)   |   | |
Good morning. I got some good news, I finally got the armature out after spraying some WD 40 penetrant overnight and gave it a big tap with a hammer and got it out.
Post# 452076 , Reply# 7   4/27/2022 at 09:51 (729 days old) by VacsofProsper (TX)   |   | |
Texaskirbyguy, Hi. I'm actually planning on putting this armature on a 12 amp motor from a Hoover upright w/removable tool rack after accidentally messing up the motor a couple weeks ago while cleaning it up top to bottom. The bearing on this turns good still believe it or not but some of the rust still need to come off.
Post# 452077 , Reply# 8   4/27/2022 at 10:02 (729 days old) by kloveland (Tulsa)   |   | |
Your armature can probably be saved as Rob mentioned. This is why I pickup Elites and their variants when I can. Especially the earlier Elites. I'm 37 and in the 90s and mid to early 2000s these were fairly common vacs. I know some collectors cringe at these. I've heard some collectors say the convertible started the downfall of Hoover. It's all about prospective and the passage of time.
Hope you get your Caddy Vac working again. |
Post# 452079 , Reply# 9   4/27/2022 at 10:28 (729 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Convertible made Hoover their fortune. well, certainly added a comma. Dick Pike told me himself that Elite was never supposed to replace Convertible. But, they are lighter and use fewer parts. Hoover "couldn't make them fast enough". My aunt bought one in 1997. Aside from a few belts, it's still fine. As long as people take care of their stuff...............
Post# 452122 , Reply# 10   4/28/2022 at 02:10 (728 days old) by MadMan (Chicago, IL, USA)   |   | |
