Thread Number: 43005
1940s Royal Motor Diagram |
Post# 450105   2/17/2022 at 17:47 (796 days old) by Hoover706 (Schererville, Indiana)   |   | |
Post# 450110 , Reply# 1   2/17/2022 at 21:59 (796 days old) by bikerray (Middle Earth)   |   | |
That looks like my 1950 Packard which was a rebranded Royal
Post# 450117 , Reply# 2   2/18/2022 at 02:23 (796 days old) by hygiene903 (Galion, OH)   |   | |
But I can help you with the oiling procedure. You should have two oil ports, one in front just behind the fan case and one in the back. They will either have a plastic or metal cap on them, and the metal cap will be threaded and have a slot for a screwdriver. Remove these caps and put 6 drops of oil in each port once a year. The oil I recommend is 3-In-1 ELECTRIC MOTOR OIL, which is a special oil that 3-in-1 makes specifically for electric motors. It is in a red, white, and blue bottle. DO NOT USE regular 3-in-1 oil, as it is too thin. The special electric motor oil might be hard to find, although Lowe's had plenty the last time I needed it. If you can't find it, use your favorite brand of SAE 30 automotive motor oil. Hope this helps,
Jeff |
Post# 450199 , Reply# 3   2/19/2022 at 22:28 (794 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 450248 , Reply# 4   2/21/2022 at 19:18 (792 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 450249 , Reply# 5   2/21/2022 at 19:23 (792 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 450295 , Reply# 6   2/22/2022 at 16:53 (792 days old) by Hoover706 (Schererville, Indiana)   |   | |
Bikerray, the vacuum I have is a Packard but it is a model 1941. Hygiene903, thank you for the oiling tips as they will come in handy. MadMan, yes I know that it is just a switch and a motor but not every motor is built the same. KirbyClassicIII, thank you for the videos as they will also come in handy when disassembling the motor.
Post# 450296 , Reply# 7   2/22/2022 at 17:27 (792 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
