Thread Number: 42987
Electrolux 1205 motor wanted |
Post# 450001   2/10/2022 at 13:54 (778 days old) by Zenith12 (Canfield Ohio )   |   | |
The motor in my 1205 failed. The brushes arc a lot even after sanding the commutator so I think I need a motor.
Post# 450010 , Reply# 3   2/10/2022 at 19:19 (777 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Joel is correct on his assessment, the carbon brushes sticking could very well be a issue. However, I would also try reseating the carbon brushes and see if that helps. This could very well help since the problem started after sanding the armature.
If it is indeed the commutator going, there is a seller on Ebay, mickeymackmark1, who has the commutators for the early and late 1205 motors. So at least you could get one and take it into a Aerus dealer to have your motor fixed and get new carbon brushes installed too. Rob PS - For anyone reading this, DO NOT SAND YOUR MOTOR COMMUTATOR! Use a armature stick instead from your local vac shop. If you sand the commutator, it can ruin it by sandpaper grit getting stuck in the grooves. A armature stick will not only clean up the commutator, it will help the carbon brushes seat correctly and is much safer. |
Post# 450021 , Reply# 5   2/11/2022 at 16:25 (777 days old) by Zenith12 (Canfield Ohio )   |   | |
When I sanded the commutator I made shire that the gaps were clean. I have a armature growler . It does have 3 burnt com bars. |
