Thread Number: 42912
Rexair Model B Main Bearings?? |
Post# 449312 , Reply# 1   1/18/2022 at 08:30 (826 days old) by Bikerray (Middle Earth)   |   | |
The top bearing is now a 88500
The bottom bearing is now a 88502 When you take the bolt out of the top end of the armature it is a left hand thread. This bolt is a Bearing Retainer Screw On the lower bearing there is a Bearing Shield and Slinger Ring on each side of the bearing. If you want the original part numbers (which are most likely no longer valid) Upper bearing R322DP175 Lower Bearing R321DP175 Bearing Retainer Screw R341DP10 Bearing Shield R146DP03 Slinger Ring R147DP03 |
Post# 449313 , Reply# 2   1/18/2022 at 08:59 (826 days old) by dysonman1 (the county)   |   | |
When you pull out the armature to remove it from the bearing in the plate, be very sure to lay the fans, spacers, and flats out exactly. The fans, both stationary and revolving, plus the eddy plate and motor housing (with carbon holders and field coil removed) can all go in the dishwasher. Use powder, not liquid or tablet detergent and use the long pots cycle. Will save you from scrubbing by hand. The lower bearing plate, with the lower bearing removed, is also able to be washed in the dishwasher.
Post# 449332 , Reply# 4   1/18/2022 at 15:37 (826 days old) by Bikerray (Middle Earth)   |   | |
88500 and 88502 are the bearing numbers, not part numbers, you will see those numbers on the side of the bearing.
A New Departure bearing will have the number 88500 K. The lower bearing may be a NDH bearing which would have a number of 3202 BG. If you go to your local bearing shop and ask for an 88500 and 88502 they will know what bearings you need. The 88500 should be about $8.50 and the 88502 should be about $9.50 |
