Thread Number: 42758
How Do I Take Apart A Hoover Model 28 Brushroll? |
Post# 448340   12/5/2021 at 13:25 (871 days old) by Elecroluxmodel1 ( Schererville, Indiana)   |   | |
Ever since I purchased my Hoover model 28, the brushroll has been very rumbly and to be honest it sounds like it has rocks in it. I tried to disassemble it but I could only get off the brush strips(which are very worn down) and one end cap(which I cleaned and polished to the best of my ability). I am not sure how to get the brushroll's axel out so any help would be appreciated.
Post# 448365 , Reply# 1   12/6/2021 at 07:34 (870 days old) by bnsd60m9200 (Akron OH)   |   | |
unscrew the other endcap. GENTLY pound the other exposed end of the brushroll shaft out with a rubber mallet. should pop out the other end enough to grab it out with pliers or your hands.
then used pliers to hold the shaft in place and unscrew the end cap still stuck to the shaft. you may or may not need another pair of pliers to unscrew the other encap while holding the shaft in place. |
Post# 448366 , Reply# 2   12/6/2021 at 08:10 (870 days old) by bikerray (Middle Earth)   |   | |
Post# 448401 , Reply# 3   12/6/2021 at 19:51 (870 days old) by Elecroluxmodel1 ( Schererville, Indiana)   |   | |
You helped me get the other end cap off! I was going to use pliers at first but I was worried that it would damage the threads on the axel. Well I got it apart and found out that it was loaded with fine dust and some coarse dirt. I also discovered that both thrust bearings were rusted and worn out. If someone can tell me where I can get new thrust bearings I would greatly appreciate it!
Post# 448407 , Reply# 4   12/6/2021 at 21:24 (870 days old) by bikerray (Middle Earth)   |   | |
