Thread Number: 42718
Central Vacuum Hose Issue |
Post# 448149 , Reply# 1   11/26/2021 at 16:19 (879 days old) by Centralvacs1928 (Chicagoland)   |   | |
That is the hose switch. You can try squirting a little spray lube in the switch and rapidly switching back and forth. That has worked for me before. Otherwise just replace the switch and receptacle assembly and you'll be good to go. |
Post# 448171 , Reply# 2   11/28/2021 at 11:29 (877 days old) by sweeperboy (Pennsylvania)   |   | |
Thanks for the suggestion. Lubricating the switch worked. I appreciate your help. |
Post# 448206 , Reply# 3   11/30/2021 at 09:36 (876 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
