Thread Number: 42635
HOOVER 541 bearing play as a result of wear |
Post# 447577 , Reply# 1   11/2/2021 at 22:04 (903 days old) by bikerray (Middle Earth)   |   | |
Post# 447604 , Reply# 2   11/3/2021 at 19:30 (902 days old) by watsonw (Newport, Shropshire, UK)   |   | |
but where to find the new bearings and reamer? |
Post# 447605 , Reply# 3   11/3/2021 at 19:57 (902 days old) by Hoover300 (Kentucky)   |   | |
Post# 447608 , Reply# 4   11/3/2021 at 21:51 (902 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 447646 , Reply# 5   11/4/2021 at 22:01 (901 days old) by bikerray (Middle Earth)   |   | |
The motor bearings in the 541 are just bronze sleeve bearings.
Since this isn't a Robbins & Myers motor you don't have to worry about the set screw holding the bearing in. The bearings on a 541 motor are driven out with a drift pin tool, the new bearings are driven in with the drift pin tool. You then need to bevel the inside edges of the lower bearing. Try fitting the armature in the bearings for fit. If the bearings are too small you will need to ream them out. Put the motor back together, there shouldn't be any side play but the should be some end play (the armature will slide up and down in the bearings) about 1/64" if there is more than that install a fiber washer at the top end of the armature to compensate for play. If there isn't any end play you may have to mill the lower bearing. Sounds like a fun evening project at the kitchen table. |
