Thread Number: 42475
Electro-Hygiene model 401 |
Post# 446575 , Reply# 1   9/27/2021 at 12:38 (941 days old) by Hoover300 (Kentucky)   |   | |
Definitely worth a service! The cord is an off brand Kirby cord, and can easily be replaced with a standard extension cord via the small white pigtail cord coming out of the motor. Do you have a hose? If so, make sure it is rubber or vinyl. Cloth ones tend to develop leaks over time. A vac shop can put a vinyl hose on the original hose ends, if need be.
As for year, maybe late 60s? I'm not an expert on PA Geier vacs. The only thing to watch out for are those wheels. If you have genuine hardwood, they will scratch if they aren't rubber. I recommend gluing some felt on them, I've done it on an old Eureka canister and it works well. |
Post# 446578 , Reply# 2   9/27/2021 at 13:56 (941 days old) by Lesinutah (Utah)   |   | |
Vacuum is an excellent vacuum. It will clean your house great. Here is a couple odd suggestions for the wheels rubber bands, duct tape dip wheels in plastic dip put vacuum belts from a hand vacuum on the.. the easiest and quickest is probably duct tape.
I don't know if the vacuum would need serviced. I'm pretty sure they take royal type j bags. The bags in the link come with a new filter. Throw awY the old filter wash the bag with the metal ring and air dry. Put dried bag in then the type j bag and your done. There not really going to do much more than that. CLICK HERE TO GO TO Lesinutah's LINK on eBay |
Post# 446586 , Reply# 4   9/27/2021 at 17:21 (941 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Kate,
What you have is a 1969-70 Electro-Hygiene model 401 Pony. The reason I start at 1969 is that was when the nameplate changed the name of the manufacturer from "P. A. Geier Company" (what Royal had traded as until 1949) to "Royal Appliance Mfg. Co." (its formal name since 1953). Oddly, the reason Royal continued using the name "P. A. Geier" from 1949 to 1968 on their Electro-Hygienes was in order to establish Electro-Hygiene as its own brand. ~Ben |
Post# 446591 , Reply# 5   9/27/2021 at 18:37 (940 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Just your standard motor service will be all it needs, it's in great condition as it is.
If you're not interested in making it a museum piece taking it back to as it left the assembly line, the cord on there is fine and is in good shape. Looks like it was recently done. That plug looks like it's from one of those new fancy power strips with the decorative fabric cords. I wouldn't change it. Any extension cord would look horribly hideous, way too long, and be way too heavy to lug around. The only thing that would concern me is the prongs overheating at the adapter connection, but this vacuum doesn't draw that much amperage so it should be okay. You can mask off the wheel face front and back and coat the wheel rim in flexSeal to give yourself a rubberized tread for your floors, unless you don't care about scratches in the varnish, then in that case leave it as is. You can go to a vacuum shop and see if you can get a reproduction hose and tool kit to fit on there and a motorized universal power nozzle (Riccar Volt) to make it a powerhead cleaner if you want to. But this machine was made when people had hardwood floors so a basic toolkit would do you just fine. You might be able to get away with using some Electrolux tools in blue to match the vacuum's color if they cooperate with the hose diameter as well. Just know it's a simple no frills cleaner, how it used to be, don't expect gold from a coal mine. You get one option, on or off, that's it. If you don;t see yourself needing any more than that, go for it. It will outlive you, your house, and everyone else if taken care of. |
Post# 446638 , Reply# 8   9/28/2021 at 20:35 (939 days old) by human (Pines of Carolina)   |   | |
Whether you get a hose and tools for your Electro-Hygiene or you go for a fully kitted out Electrolux canister, you really can't go wrong. They're both great options and will give you far more vacuum for the money than any newer plasticrap machine.
One thought if you decided to go the Electrolux route, you could always sell the Electro-Hygiene here on the 'Super Market' forum, put that money toward what you want and be comfortable in the knowledge that whoever ends up with it will take good care of it. One place you might check is shopgoodwill.com. I recently got a Kirby Classic III from there for less than $30 shipped. |
