Thread Number: 42431
My sweet new Electrolux 1205 |
Post# 446209 , Reply# 1   9/18/2021 at 19:28 (948 days old) by human (Pines of Carolina)   |   | |
Nice machine but interesting collection of accessories. The gray plastics on the PN4 would indicate that it went with a Silverado but I'm wondering if somebody switched the cover with one from an earlier power nozzle. I thought the polished aluminum covers were discontinued by the time the Olympia came out and that the Silverado shipped with gray painted PN4A that had the motor hump running only partway across. That's obviously a cover for an earlier PN4 the full width motor hump. The PN4 came in polished aluminum with the Super J. Some early Olympia Ones got the polished aluminum PN4 also but most were painted brown. Also, is that a non-electric hose?
Post# 446226 , Reply# 3   9/19/2021 at 13:39 (947 days old) by human (Pines of Carolina)   |   | |
Per your request, below are pictures of (L to R) a PN2, PN4 and PN4A in Silverado gray. It's easy to mistake the PN4 for a PN2, especially with the polished aluminum cover, but if you compare the PN2 and PN4, you'll notice the elbow where the wand connects is set further forward on the PN2 while the PN4 and 4A have the elbow slightly protruding from the rear of the nozzle's body. Looking underneath, the PN2 has three cylindrical rollers while the PN4 and PN4A have two wheels, one on either side of the elbow. Other than cosmetic features, the PN4 and PN4A are pretty much identical except for the motor hump, which only extends about 3/4 of the way across the cover on the 4A. The 4A also has a slightly longer elbow and lacks the metal ring at the top. The PN4A also has a painted cover, either brown for the Olympia or gray for the Silverado. This is unfortunate because the 'battle scars' show a lot worse on the painted covers, especially the brown ones. In that respect, you're lucky that yours has the polished aluminum cover, even if it isn't original to that power nozzle.
The PN2 always had a white bumper and originally had a teal elbow. That version was paired with the Model G (I think), 1205 and Golden Jubilee models. The Jubilee version came with a 50th anniversary decal. The ones with a white elbow like mine would have been paired with either a Golden Jubilee or a Super J. The PN4 with the polished aluminum cover was paired with the later Super J's and early Olympias before they began painting the covers brown (big mistake, IMO). They transitioned to the PN4A during the Olympia era but the plastics were off white. The Silverado got the gray plastics to match those on the vacuum cleaner itself. Please understand I was not running down your machine in any way. I was just pointing out an unusual characteristic of your power nozzle, which happens to be a 'plus' in my book. I strongly prefer the look of the polished cover. A few years ago, I tried to strip the paint off of a PN4A cover with the idea of polishing it up but I never could get the paint completely off, except for the 'Electrolux' nameplate area. I finally gave up and repainted it with Rustoleum Hammertone Black paint and primer in one, the color of which is really more of a gunmetal gray. Just for fun, I polished up that nameplate area and masked it off before I painted the cover. The color is slightly darker than the original and the textured paint hid a world of sins. The polished nameplate really made the whole thing pop. They should have done them that way at the factory. I've been very tempted to give the PN4A in the pictures the same treatment, although if a polished PN4 cover were to come my way for a reasonable price, I'd slap it on there in a heartbeat. |
Post# 446278 , Reply# 5   9/20/2021 at 11:57 (946 days old) by human (Pines of Carolina)   |   | |
Very cool. I really like the PN2. I think the geometry of the center mounted elbow makes it a little more maneuverable in tight spaces. I also prefer the roller arrangement, which is similar to the PN1. It also has a closed dirt path that keeps the motor cleaner. they simplified the design for the PN4/4A, which allows the inside to get a little dirtier. I certainly wouldn't lose any sleep over the white elbow vs. teal.
The one design feature the PN4/4A does have over the PN2 is the permanently attached pigtail cord. The one on the PN2 has a tendency to fall out at the machine end. This design flaw apparently drew enough customer complaints that Electrolux offered a three-piece metal retaining clip to hold it in place. Those are pretty much unobtainable these days but I've found that you can accomplish the same thing by fishing the pigtail through the top cover so that the bottom of the Mayan pyramid shaped plug is underneath the cover. Getting the cord through is the easy part. The head of the plug then takes some persuading but once it's through, you just need need to make sure the plug lines up properly as you press the top cover into place. It might take a try or two, but once everything is screwed back together, it shouldn't fall out. |
Post# 446695 , Reply# 8   9/30/2021 at 21:11 (936 days old) by eurekaprince (Montreal, Canada)   |   | |
