Thread Number: 42278
How was Hoover's twin chamber bagless system really? |
Post# 444974   8/21/2021 at 22:18 (949 days old) by fan-of-fans (USA)   |   | |
I've noticed vacuums like the Hoover bagless Windtunnels, Savvy, etc used Hoovers twin chamber setup. Was this a good setup?
My only experience with it is a Hoover Empower that a friend had in college. When he moved back home I used it to vacuum off a futon and it had horrible suction through the hose - I mean a straw would be stronger suction! But I bet he never cleaned the filters. Was a neat vacuum otherwise, I liked the power surge switch on the handle and how the main switch had both on and hush modes. I don't know, I've never cared for pleated filters in uprights - paper or otherwise. Always logged up with hair and fine dust after cleaning just one or two rooms. In fact to me, the first good bagless systems were when they started coming out with the rinseable pad filters and using true dual cyclonic separation. The old single cyclone design or what is basically a dust cup with a filter just did not work well in practice. |
Post# 445012 , Reply# 1   8/22/2021 at 21:27 (948 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Not very good in my experience, which is too bad because otherwise Hoover made great machines. I bought an EmPower new in 2005 and it had really strong suction and a good brush roll, but the twin-chamber setup was awful. Suction loss wasn't very noticeable (I even used the arm and hammer carpet refresher occasionally), but cleaning the filter was nasty. Clouds of dust every time. You had to disassemble the filer and knock it against the garbage can so it didn't clog. I'm not surprised your friend's empower lost suction if it wasn't very well taken care of. I replaced my filter maybe 3 or 4 times during the few years I owned it.
I've also owned a Hoover Bagless, which was the original twin-chamber model with an Elite motor. It was a true direct-air machine that just replaced the normal bag set up with a bin. Again, nice late-model Elite, cleaned carpets great, but the twin-chamber just destroyed it. You could see dust blown out of the bin every time you turned it on. The seals would leak pet hair near the lid. When it was new with new seals it might have been better, but the direct-air fan-first set up just does not work with that kind of bagless after years of use. The difference between what Hoover and Fantom or Dyson was offering at the same time was huge. You can empty a Fantom or Dyson with almost no drama and almost no maintenance. Sadly that wasn't the case with the Hoovers. Someone else definitely knows more about this than me, but I think the only reason the twin-chamber existed was to compete with Fantom, but Dyson had the patents to the only real cyclonic technology. As soon as engineers either found a way to build dual-cyclone machines without infringing on patents, or Dyson's patents just simply expired, they started selling their own cyclonic machines and twin-chamber was pretty quickly taken off the market. If I remember correctly this took place around 2009 when the T-Series made their debut. |
Post# 445125 , Reply# 2   8/24/2021 at 21:53 (946 days old) by fan-of-fans (USA)   |   | |
I would agree with you. And it wasn't just Hoover that was this way, but most any of the bagless upright vacs of the late 90s and early 2000s were far inferior.
The Eurekas and earlier Panasonics/Kenmores and Bissells also all had the pleated filters that clogged easily, some had various designs to slightly separate the filter from the dust bin, but all required lots of work to maintain. I think you are right on the patents expiring, because it really was around 2009/2010 when all of the other manufacturers started designing TRUE dual cyclonic bagless uprights that didn't have the clogging issues of their earlier models. Up until then the only really good bagless uprights I'm aware of were the Fantoms/Vectrons, Kenmore-branded Fantoms and the Amway Cleartrak. All variations of the Dyson design. Nobody else would have been allowed to use it. The Amway Cleartrak is the only one of those I know of still in production. |
Post# 445192 , Reply# 4   8/26/2021 at 21:50 (944 days old) by fan-of-fans (USA)   |   | |
Those things sound like the Kenmores of that time in a way.
My mom had a Kenmore Quick Clean bagless, the pleated filter was in a separate section on top of the dust bin. You lifted out the bin and then the two sections came apart to empty. There was a plastic disc with holes in it that went over the filter. It did pretty good at capturing hair and large particles before they went into the filter. Still all the fine dust got stuck in the filter though. I have a Kenmore Progressive bagless, and there is a lever on the handle of the dust bin that moves a little piece that flicks dust from the filter. That's supposed to knock the dust loose, then you press the button which dumps the dust out the bottom of the bin. On this one the filter is situated in the dust bin itself with no separation. |
