Thread Number: 42039
Another 505 detail to share |
Post# 443403   6/27/2021 at 14:22 (1,031 days old) by Vacmadman (Pueblo Co.)   |   | |
Pictured are two 505 in process I noticed this a few years back. If you look closely at the handle lock screw heads they have a perfect round or dome shape to them.
I noticed that later 500 series models these screws are flattened at the very tip top of the screws. I think this change began with the late model 508....Thought's?? Jim
This post was last edited 06/27/2021 at 14:44 |
Post# 443414 , Reply# 1   6/27/2021 at 21:32 (1,031 days old) by Lesinutah (Utah)   |   | |
Post# 443438 , Reply# 3   6/28/2021 at 15:57 (1,030 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Billy,
I will share with you everything I know about when Kirby used Phillips screws, and where... 1960 - model 560 Where: Motor shell housing (3) Belt lifter assembly (3) 1962 - model 562 Sanitronic Where: Wheels (4) 1964 - model Sanitronic VII Where: Front wheel shaft clamp (2) Front bearing plate (4) 1970 - model Classic 1CR Where: Rear wheel shaft (2) 1973 - model Classic Omega 1CB Where: Fan housing/motor housing (long 1-1/4" screw on front of fan case, above suction intake opening) 1974 - model Classic Omega 1CB Where: Fan housing/motor housing (four short 5/8" screws on back of motor housing; three round head and one flat head) 1979 - model Tradition 3CB Where: Headlight lens (2) Vent seal (2) Speed switch (top mount)/terminal block retainer bar (2) ~Ben |
