Thread Number: 42023
Electrolux hose pipe |
Post# 443337 , Reply# 1   6/26/2021 at 12:35 (1,028 days old) by Human (Pines of Carolina)   |   | |
You haven't specified which end of the hose you're working on. If you are trying to remove and replace the connector on the end that attaches to the vacuum cleaner. Unfortunately, it is not a user replaceable part. It was permanently attached at the factory. Even Aerus/Electrolux dealers can't fix them.
If you are working on the other end of the hose, which connects to the wand and/or tools, you're in better luck. The grip is easily removable. Just remove the two screws on the underside and carefully lift off the cover they hold in place, starting at the end closest to the metal tip so that the end closest to the hose itself comes off last. Be gentle because that cover is fragile. Once that is removed, the grip slides right off. All that said, if the hose you're working with is a woven one, chances are it's shot anyway. They tend to deteriorate from the inside and leak badly. There is no real way to repair that. If the hose looks presentable, it's okay for display purposes but if you want to actually use the cleaner, your best bet is to go ahead and get a good, genuine Electrolux vinyl replacement hose. They aren't cheap but they're well worth the cost. You'll be amazed how much the performance of your vacuum improves with a new hose in place. Decent used ones show up on eBay at affordable prices. Be patient and persistent and you'll find what you need. |
Post# 443707 , Reply# 4   7/8/2021 at 11:51 (1,016 days old) by jakobbruwer (Ashton)   |   | |
ok |
Post# 443860 , Reply# 5   7/14/2021 at 17:32 (1,010 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Vinyl hoses look wretched and throwing out the original hose makes it harder and harder for people to find them anymore. I had to pay $90 to get the original hose for an Electrolux E and even then it was still rotten and had to be repaired. Keep the original hose but coat the insides with FlexSeal. It will be better than a vinyl hose and not look ugly.
www.vacuumland.org/cgi-bi... |
