Thread Number: 41883
Tristar tec? Need power head |
Post# 442365   5/29/2021 at 13:40 (1,061 days old) by Venaka (Leesburg)   |   | |
I have the tristar dxl and I never had the power nozel that goes with it. I was wondering if its worth paying the $100 i see in ebay used or go with any other power head u guys recommend. |
Post# 442371 , Reply# 1   5/29/2021 at 17:13 (1,061 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
For a Tristar cxl/dxl the original pn works great you can make it better with a vibra groomer 2 brunshroll keep an eye on ebay for a good deal .
This post was last edited 05/29/2021 at 20:18 |
Post# 442384 , Reply# 2   5/29/2021 at 22:02 (1,060 days old) by Lesinutah (Utah)   |   | |
Post# 442400 , Reply# 3   5/30/2021 at 16:30 (1,060 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
For Originality only the factory will do .Now you can make your tristar cxl dxl C8 C9 a supercharge cleaning monster with the vibra groomer 2 or 3 brushroller ./ orrrr you can do a resto mod and go Werveck german pn ebk 360 your choice both are good .But personally my tristar cxl 50 and Compact electra interstate both run there factory bushroll and pn .
Post# 442401 , Reply# 4   5/30/2021 at 16:37 (1,060 days old) by Lesinutah (Utah)   |   | |
Post# 442482 , Reply# 6   6/1/2021 at 21:47 (1,057 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 442483 , Reply# 7   6/1/2021 at 21:51 (1,057 days old) by Lesinutah (Utah)   |   | |
It will fit I'm attaching a link to the cheapest I could find. The handle should plug into the handle of your handle.
It's the best power nozzle on the best canister. It's a beast and you'll love it. CLICK HERE TO GO TO Lesinutah's LINK on eBay |
Post# 443535 , Reply# 8   7/2/2021 at 11:19 (1,027 days old) by Venaka (Leesburg)   |   | |
Can't see how to connect this. I tried to use the wand it came with and my hose will not connect to it..the two pings can't fit correctly..am I doing something wrong.. |
Post# 443536 , Reply# 9   7/2/2021 at 12:16 (1,027 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Dont think hose will fit the tristar you have youd need a adpter to insert hose in weslverk wand and a pig tail. This post was last edited 07/02/2021 at 12:34 |
Post# 443537 , Reply# 10   7/2/2021 at 12:42 (1,027 days old) by Venaka (Leesburg)   |   | |
This is getting complicated ..should have just stuck with the original ph...dont know what adapter is needed ..ill check it more closely when I get home. |
Post# 443544 , Reply# 11   7/2/2021 at 14:57 (1,027 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 443555 , Reply# 12   7/2/2021 at 22:24 (1,026 days old) by Lesinutah (Utah)   |   | |
Post# 443570 , Reply# 13   7/3/2021 at 13:57 (1,026 days old) by Venaka (Leesburg)   |   | |
No it did not ..not on my setup . It will not fit ...the wessel wand does not fit on the gun of the hose of the tristar. Someone said i needed the long neck ph. Not sure , but I have tried multiple times. Maybe I got the wrong hose or wessel |
Post# 443572 , Reply# 14   7/3/2021 at 14:35 (1,026 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 443582 , Reply# 15   7/4/2021 at 04:42 (1,025 days old) by Blackheart (North Dakota)   |   | |
I saw your other thread too before you sell this off I think you can make this work.
That nozzle and wand will not be compatible with the stock hose since they are a direct connect type rather than a pigtail (having a cord) So what you appear to have gotten seems to be for adding a power nozzle to backpack vacuums, the good news here is that this appears to be a wessel werk retrofit hose which should be able to be converted to use with your tristar. First you'll need to change the machine end on the black hose. That piece circled in red should be able to disconnect from the hose it should just be held in via friction if you get that off you'll want to get this part in the link it will just pop into place when inserted and you'll be able to plug the black hose into the tristar. As for the electrical connection you should be able to disconnect it at the green arrow to get a 2 pin connector, now i'm not sure if it's long enough to make the distance to the power nozzle plug on the body of the machine, as it looks rather short in the photo, but if it's not there's no need to worry these too are replaceable If you take these steps and convert the hose you'll find it far more convenient as you'll have an on/off switch for the power nozzle at your fingertips enabling you to more easily clean hard floors If you need further assistance or are having a hard time I can provide a video walkthrough on this as I have two hoses around that are very similar to yours CLICK HERE TO GO TO Blackheart's LINK on eBay
Post# 443583 , Reply# 16   7/4/2021 at 04:52 (1,025 days old) by Blackheart (North Dakota)   |   | |
Hmm looking closer it almost appears the electrical cord is like melded together so it would require replacement and in scouring ebay for the part it appears you have already listed your set for sale so perhaps too late for advice
Well I did find a pigtail that should fit between the hose and machine body it may be a little long but I didn't think the 11" versions would be long enough CLICK HERE TO GO TO Blackheart's LINK on eBay |
