Thread Number: 41837
Gear Problems |
Post# 442026 , Reply# 1   5/20/2021 at 14:47 (1,070 days old) by Hoover300 (Kentucky)   |   | |
Post# 442032 , Reply# 2   5/20/2021 at 19:06 (1,070 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Brass is a very soft metal and in an application like this it will have worn down to where the gears wobble on their axis and bind. Filing it down would exacerbate the issue because you have changed the toothing depth of the gear and increased the tolerance, allowing it to skip or the teeth to fit too snugly into each other and lock in place.
The only way to know is to find someone with a mint condition one (museum) that has barely been used and closest to new and that would check the measurements of the gears with calipers or let the gears be molded and copied from. Then compare those measurements to yours. Another way that might work is try and reverse engineer the gears based on their fitments now and try and rebuild their original tolerance until you get smooth operation, would take a lot of trial and error though. Thanks to CNC machines, re-creating and replacing the gears is not at all impossible, however knowing the measurements to begin with is key. I'd try and find someone somewhere that deals with mechanical stuff like this and see if help can be found there. Maybe a knowledgeable engineering professor or a R/C car builder, transmission mechanic, I have no idea. Someone that knows about gear mechanics. There has gotta be someone out there that can solve this. |
Post# 442068 , Reply# 3   5/21/2021 at 15:07 (1,069 days old) by Lesinutah (Utah)   |   | |
Post# 442079 , Reply# 4   5/21/2021 at 21:32 (1,069 days old) by MadMan (Chicago, IL, USA)   |   | |
