Thread Number: 41539
My first Convertible |
Post# 440087   3/20/2021 at 21:49 (1,103 days old) by fan-of-fans (USA)   |   | |
So for the last 3 1/2 months now, there's been a very BOL Hoover Convertible at my local Habitat. I kept going, looking at it, and deciding to pass.
Today I decided to get it. It's very BOL - no headlight, no hand grip, single speed, only half bumpers, no beater bars, two position height adjust. But I still like it. It's a model U4373, which I don't find much info on. It's clearly a later model - it's plastic base, plastic fan, and it has the slider switch with plastic switch plate. If I had to guess, I'd say mid 80s? It's older than 1987, I know because there's no date code in the serial number. Anyway, when I get time tomorrow I plan to start dismantling it and cleaning it up. I think it's going to turn out nice. I've ordered some genuine green C bags. I'm also kicking around the idea of getting a set of simple U4901 attachments for it. I just want to see what the hose suction is like on a single speed Convertible. I'll post some photos once I get everything cleaned and polished up. |
Post# 440091 , Reply# 1   3/20/2021 at 23:32 (1,103 days old) by Lesinutah (Utah)   |   | |
Post# 440117 , Reply# 2   3/21/2021 at 15:17 (1,102 days old) by fan-of-fans (USA)   |   | |
Post# 440234 , Reply# 3   3/23/2021 at 21:00 (1,100 days old) by fan-of-fans (USA)   |   | |
So over the weekend, despite the dreary and chilly (by Florida standards) weather, I did manage to get a little cleanup done.
I got the hood washed up and polished, as well as the nozzle plate. After that, back indoors I got the handle all cleaned and waxed and got some cleanup done on the base and motor. Still need to wash the bag and get the rest of the undersides and wheels cleaned, but it is coming along. Not in bad shape at all really and the only rust was on the plate that holds the rear wheels and bag on. I also found an owner's manual for this model on eBay, so that is on the way. The manual has a date of 1985, so I presume that is about the right year for this cleaner. |
Post# 440466 , Reply# 4   3/30/2021 at 21:32 (1,093 days old) by fan-of-fans (USA)   |   | |
Some more progress last weekend. It was beautiful weather, so I soaked the vinyl bag in some soapy water, and scrubbed the remaining dust and grime out. I put it in the sun to dry, but it still smells like old dust. Might have to get some Pine Sol or something to soak it in for a day or so.
Also got the base disassembled for cleaning. The owner's manual arrived today in the mail and I also got some genuine Hoover C bags for it. |
Post# 440469 , Reply# 5   3/31/2021 at 08:49 (1,093 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 443102 , Reply# 6   6/19/2021 at 16:36 (1,012 days old) by fan-of-fans (USA)   |   | |
I've finally gotten back around to working on this. In taking the motor out for cleaning, I discovered the fan had a big crack in the bottom. I ordered a new one, but I am having a very difficult time getting the screw out to replace it.
I read a thread that suggested to insert a small screwdriver into hole on the side of the motor to lock the rotor. I tried this as well but it doesn't seem to be working, the screwdriver pops out as soon as I try to turn the screw. Hmm... I did manage to get the motor itself apart but there also didn't seem to be anything to really grab on to while trying to loosen this screw. The carbon brushes look good and long though. |
Post# 443104 , Reply# 7   6/19/2021 at 17:05 (1,012 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 443110 , Reply# 8   6/19/2021 at 21:26 (1,012 days old) by fan-of-fans (USA)   |   | |
Thank you, I will try something like Odoban. I did use some Lysol on it last time I was working on it and that seemed to help some. It seems any vacs I get at Habitat have a musty smell to them. It's not as noticeable in the store, but when you get them home they always have that distinct smell.
I think tomorrow I will try some penetrating oil around the pulley and see if I can get the screw out. It is really tight, I have tried multiple times with the biggest flat blade screwdriver I have and that screw will not budge. |
Post# 443339 , Reply# 9   6/26/2021 at 13:40 (1,005 days old) by fan-of-fans (USA)   |   | |
Well, I've done everything I can think of and I can't get the screw off this fan! I put a vice grip on it and tightened as hard as I could and it will not come loose, the grip just slips off.
Does anyone have any tips? I thought of spraying something to get it loose, but I don't see anywhere to get any oil around the screw, it's tight up against the fan. |
Post# 443346 , Reply# 10   6/26/2021 at 15:54 (1,005 days old) by Kloveland (Tulsa)   |   | |
Post# 443354 , Reply# 11   6/26/2021 at 17:29 (1,005 days old) by Dysonman1 (the county)   |   | |
Post# 443361 , Reply# 12   6/26/2021 at 19:58 (1,005 days old) by fan-of-fans (USA)   |   | |
