Thread Number: 41532
Kirby Heritage II commutator brushes |
Post# 440056 , Reply# 1   3/20/2021 at 02:21 (1,127 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Lou,
The ones you want for your Heritage II will be stamped "HG22" on the carbons. They are installed in more or less the same manner as those for models 519 to Dual Sanitronic 80. The older carbon brushes you want for your 519 would be stamped "B75." ~Ben |
Post# 440079 , Reply# 3   3/20/2021 at 19:04 (1,126 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 440090 , Reply# 4   3/20/2021 at 23:27 (1,126 days old) by Lesinutah (Utah)   |   | |
You probably had it wired backwards . If you decrease power when hose is on and increase when nozzle is on. That's basically the exact opposite of how it should work.
The brushes will run like a car running out of gas. It will bog and be loud. I'd check the wiring. The wiring is off the power switches unless you catch on fire don't fail. Check the wiring and you will find the issue. |
