Thread Number: 41296
Another Kirby 505 motor to start work on part 2 |
Post# 437950   1/29/2021 at 13:20 (1,182 days old) by VacMadMan (Pueblo Co.)   |   | |
Well this 505 motor has been thoroughly cleaned and polished and is ready for reassembly. Unfortunately the light cap was cracked on both sides so I decided to remove the light cap trim that is in good condition. I do have a 505 light cap that I can replace it with that needs the trim....there's a first time for everything, but I love the challenge.
Post# 437951 , Reply# 1   1/29/2021 at 13:36 (1,182 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 437987 , Reply# 2   1/30/2021 at 13:20 (1,181 days old) by VacMadMan (Pueblo Co.)   |   | |
I got this old 505 back together, and just for fun I put on a Kirby 2C nozzle with the belt cap, and just like that I have a pre-belt lifter 505....LOL!!
Post# 437995 , Reply# 4   1/30/2021 at 16:39 (1,181 days old) by VacMadMan (Pueblo Co.)   |   | |
Post# 438044 , Reply# 6   1/31/2021 at 21:58 (1,179 days old) by Lesinutah (Utah)   |   | |
The model 1c had a safety switch. It's been around atleast since model c.
The switch makes it so the vacuum won't turn on unless nozzle or hose is in place. The 500 series 2 wires +,- from light, 2 +, - coil, ground power from carbon brushes. The all connect to the switch. The wiring is ran on the outside of the vacuum from the switch underneath to the safety switch. If you went to the switch and didn't hook up safety switch wires it would turn on when you power on the vacuum. |
Post# 438066 , Reply# 7   2/1/2021 at 18:08 (1,178 days old) by kirbyklekter (Concord,Ca.)   |   | |
Thanks Les, it just looks so different than the other Kirby's that came later. |
Post# 438069 , Reply# 8   2/1/2021 at 18:50 (1,178 days old) by quebecois (Waterloo, Canada)   |   | |
Fantastic look ! DId you do all this polishing by hand or did you use a felt wheel or a cotton wheel and a buffer? |
Post# 438071 , Reply# 9   2/1/2021 at 19:05 (1,178 days old) by Lesinutah (Utah)   |   | |
Post# 438076 , Reply# 10   2/1/2021 at 21:01 (1,178 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Jim,
Here is an in-person view of the wiring diagram for models 505-515, and I believe the same applied to models 3C and 4C. ~Ben
Post# 438092 , Reply# 11   2/2/2021 at 09:22 (1,178 days old) by VacMadMan (Pueblo Co.)   |   | |
François
I use a Chicago electric variable speed close quarter hand drill. I start by wet sanding with 1500 or 2000 grit sandpaper, depending on the level of oxidation, or damage to the aluminum. I then work my way up to 3000 grit before I start polishing with a cotton polishing wheel. There are a number of different sizes and types you can use. I polish using Mother's mag polish, then I'll finish by hand polishing with Flitz corrosion protection polish. This will protect the finish for up to 6 months. If you need to remove bad or deep scratches you may want to start with 600 grit then work your way up to 3000 grit 600, 1000, 1500, 2000, 2500, 3000,...polish. Jim
Post# 439676 , Reply# 12   3/12/2021 at 03:18 (1,140 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
