Hello all,
I recently got a Hoover Windtunnel Self Propelled from Goodwill, cleaned it up and had a new switch put in. The only issue I am having now is that the Self Propelled feature is stuck on and wont turn off. I've looked into it and it there is a small crack on the actuator arm, but from the results I've seen online when I research it is that the crack would stop the self propel from engaging, not prevent it from disengaging. Am I correct in assuming this? Could it be something else? Thanks in advance. I can upload pictures if needed.
