Thread Number: 41258
MIELE PLATINUM ELECTRONIC PROBLEM |
Post# 437591 , Reply# 1   1/22/2021 at 10:07 (1,182 days old) by Kirboover (Watertown, South Dakota)   |   | |
Post# 437613 , Reply# 2   1/22/2021 at 18:19 (1,182 days old) by vacuumdevil (Vacuum Hell )   |   | |
Post# 437632 , Reply# 4   1/23/2021 at 04:07 (1,182 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 437716 , Reply# 5   1/25/2021 at 00:59 (1,180 days old) by vacuumdevil (Vacuum Hell )   |   | |
Post# 437754 , Reply# 6   1/25/2021 at 19:40 (1,179 days old) by MATTINLA (Burbank)   |   | |
Vac shop confirmed the board is bad. And it may not be available. If so, the hunt for an odd-job electronics tech to replace the Triac will be underway. These people are harder to find than a lost gold mine. |
Post# 437760 , Reply# 7   1/25/2021 at 22:01 (1,179 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 437766 , Reply# 9   1/26/2021 at 02:16 (1,179 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
The circuit board is there for a reason, its to regulate the operating temperature of the motor, motor speed, voltage, all that stuff. There is a reason why Mieles cost so much. It would be like ripping the ECU out of a modern car. They are premium vacuums.
Take the vacuum's circuit board to a computer or electronics repair shop and have them help you replace the parts individually. All you really need is to understand what parts you need, a multimeter, and a soldering gun. You really don't even need to know how they work as long as you have the right ones and copy the new parts the same way the old ones came out. That's how I've repaired a lot of stuff, lol Vacuum store clerks are not usually computer wizards and A/V geeks, and they run a business, so speaking as a whole for whoever comes in with a fancy vac like that, they do not want to risk their company (or your warranty) on replacing little components one at a time from 3rd party sellers, they will try and get the entire board directly from OEM. Of course OEM will not sell it because they wouldn't make anything off it so they want you to buy the entire motor with it. Appliance and car mechanics are getting that way too, you buy parts off eBay and expect them to install them for you, they will laugh you out the door and say that they can not do that or will not do it "its against their policy". It's getting to where if you want something fixed anymore, you have to learn it yourself. You would think they would want money and business....but I guess not. |
Post# 437779 , Reply# 10   1/26/2021 at 10:26 (1,178 days old) by human (Pines of Carolina)   |   | |
Manufacturers load their appliances up with circuit boards these days because they don't want them to last too long as it cuts into their bottom line when you don't have to replace the item on a regular basis. They also update the circuit boards' design and make the old ones obsolete and unobtainable fairly quickly to force your hand on replacing the machine. The most insidious part is in re-positioning products as "consumable," manufacturers have successfully conditioned consumers to regard said products' ridiculously short lifespans as "normal". The bottom line is your vacuum's pre-set expiration date has been exceeded and the self-destruct mechanism has thus been activated. Welcome to the age of engineered obsolescence.
Post# 437800 , Reply# 11   1/26/2021 at 22:15 (1,178 days old) by MadMan (Chicago, IL, USA)   |   | |
Jo - I don't know, depends on the design. As Husky says, it may be there for the motor's safety. Of course you could bypass it, but the real question is whether you should.
Husky - there are totally legitimate reasons why repair businesses (like mine) refuse to use customer supplied parts. There really is a liability to it, and besides that, if the cheap ebay part breaks, the customer ALWAYS thinks the repairman is at fault, because people (customers) are stupid. So it's a liability to your business's reputation as well. Also, I find it humorous how some of you believe that a tiny little one-sided pcb with literally just two components is 'complicated.' lol Try fixing any circuit board on a car. Double-sided, even multi-layered boards, with components smaller than a grain of rice - thousands of them! - that can only be repaired with specialist tools, tweezers, and the steady hands and patience of a brain surgeon. Not to mention that the ordinary car computer runs 5 MILLION lines of code. |
