Thread Number: 41008
How to safely get stubborn fancase off of Sanitronic VII? |
Post# 435351 , Reply# 1   11/22/2020 at 23:47 (1,249 days old) by Lesinutah (Utah)   |   | |
Are you talking about front fan case or the back fan case.
The 3 or 4 screws in the motor housing shell and popping off switch button. That will take the motor housing. This will give you access to the screws you weren't aware of because the motor housing was covering it. If no avail get a heavy screwdriver and an rubber mallet. Where exhaust hole is put screw driver in the hole on front casing. Give it a pop or. Two. Sealing it use atv silicone for it. V |
Post# 435354 , Reply# 3   11/23/2020 at 04:07 (1,249 days old) by vacuser (milford,ohio)   |   | |
Post# 435368 , Reply# 5   11/23/2020 at 22:13 (1,248 days old) by Lesinutah (Utah)   |   | |
Post# 435371 , Reply# 6   11/23/2020 at 22:57 (1,248 days old) by kirbyklekter (Concord,Ca.)   |   | |
Like a hair dryer 2000 watt? |
Post# 435373 , Reply# 7   11/23/2020 at 23:02 (1,248 days old) by kirbyklekter (Concord,Ca.)   |   | |
heat gun would be the way to go, thanks Les. |
Post# 435389 , Reply# 8   11/24/2020 at 13:12 (1,247 days old) by Lesinutah (Utah)   |   | |
Post# 435412 , Reply# 9   11/24/2020 at 16:59 (1,247 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 435433 , Reply# 10   11/25/2020 at 01:07 (1,247 days old) by electrolux137 (Los Angeles)   |   | |
Post# 435508 , Reply# 12   11/26/2020 at 17:20 (1,245 days old) by Lesinutah (Utah)   |   | |
You should post some pics.
The wheels available from kirby are sirocco/tan and would match the vacuum topper. If you spray a cleaner on the bumper and use a mr. Clean magic eraser or a S.O.S. brillo pad will take the scuffs off. When the trim dries if you use a car interior cleaner like Armor-all or Mageiars it will hydrate the trim. The bag if you turn it inside out and use super glue and pinch the bag together. This fixes most holes. I had 2 cigarette holes (I'm not a smoker) on my rear seats in my corolla. I used this super glue method and no more holes. |
