Thread Number: 40992
What will damage a Kirby lexan fan ? |
Post# 435279   11/20/2020 at 13:14 (1,245 days old) by Zenith12 (Canfield Ohio )   |   | |
What will damage a Kirby fan the gray plastic ones not the white ones? Am I right are the gray fans made from lexan I know that the white ones are cevlar . |
Post# 435280 , Reply# 1   11/20/2020 at 13:43 (1,245 days old) by sanitaire (anchorage, alaska)   |   | |
usually coins or items that don't fit between the blades.. not a lot of clearance.. it's built for maximum air flow.... |
Post# 435282 , Reply# 2   11/20/2020 at 14:27 (1,245 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 435283 , Reply# 3   11/20/2020 at 15:12 (1,245 days old) by vacuumkid47 (Sibley, IA)   |   | |
Post# 435284 , Reply# 4   11/20/2020 at 15:35 (1,245 days old) by Hoover300 (Kentucky)   |   | |
Post# 435287 , Reply# 5   11/20/2020 at 16:38 (1,245 days old) by Blackheart (North Dakota)   |   | |
Post# 435289 , Reply# 6   11/20/2020 at 16:39 (1,245 days old) by Lesinutah (Utah)   |   | |
The lexan fan was in kirby's 30 years ago. If you had a good condition lexan fan you would be fine under normal circumstances.
I know Rob had some blow up but like I said they were put in 30 years ago. They can't withstand heat as well as amodel or kevlar fans. I'd just spend $10 and switch it out. I have a kirby american lincoln super sweep. I took it apart and replaced it even though the original was in pristine condition. If you replace you won't have to again. |
Post# 435293 , Reply# 7   11/20/2020 at 20:26 (1,245 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
