Thread Number: 40715
Electrolux Diamond Jubilee Manual Needed!!! |
Post# 432692 , Reply# 4   9/28/2020 at 08:52 (1,303 days old) by Real1shep (Walla Walla, WA)   |   | |
the OM for the Diamond J. What exactly now, do you want from it? I can scan any of the pages and send to your email etc. It is not for sale. I think I do have an extra G OM that I might let go for $ or trade. Kevin |
Post# 432785 , Reply# 5   9/29/2020 at 09:54 (1,302 days old) by human (Pines of Carolina)   |   | |
That front swivel caster is standard on all Electrolux canisters. It helps the canister follow you as you move around a room with the hose in your hand. On the metal canisters, starting with the 1205, it is held in place with two screws and is easily replaceable. On the later plastic canisters, it is permanently attached. I have a Silverado Deluxe (immediate predecessor to the Diamond J) on which the caster had gotten worn flat on one side. Not sure how that happened. Fortunately, the caster is pretty much a commodity item. I was able to source a replacement off the shelf at Lowe's in a two-pack for about $5. It wasn't a completely perfect fit but for the price, it was close enough. The attachment plate was just a shade too narrow but by installing it at a slight angle, I was able to get the screw holes to line up, even if the locator pins on the opposite corners didn't. This was not a real problem. I just tightened the screws down securely and it's held just fine for more than a year and a half. If you want to make it more secure, just use a drop of thread lock on the screws and/or add lock washers.
