Thread Number: 40618  /  Tag: Recent Vacuum Cleaners from past 20 years
Shop Vac Grinding Noise.
Post# 431491   9/8/2020 at 17:21 (1,315 days old) by RoyalFan103 (Washington)
royalfan103's profile picture
I still have my Shop Vac Hang Up that I bought in 2018. It still makes that grinding noise whenever I turn it on. What could be going on with it? It doesn't make that bearing noise anymore so I don't need to lube it.
Post# 431492 , Reply# 1   9/8/2020 at 17:29 (1,315 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )
nie fro mthe motor bearing almosta 100% tiem to repalce the bearing on her .
Post# 431510 , Reply# 2   9/8/2020 at 23:18 (1,315 days old) by Lesinutah (Utah)
Umm
I had a Porter cable shop vac. I don't know how but a screw got jammed in the fan.
Check and make sure no foreign objects aren't in there.
Les
Post# 431512 , Reply# 3   9/8/2020 at 23:38 (1,315 days old) by broomvac (N/A)
broomvac's profile picture
The Chewbacca noise upon startup/shutdown can be cured if you put some 3-in-1 Electric Motor Oil (blue label) in the upper sleeve bearing.
Post# 431515 , Reply# 4   9/9/2020 at 01:50 (1,315 days old) by MadMan (Chicago, IL, USA)
madman's profile picture
Well, don't make assumptions. Inspect the bearings first, inspect fan blades next. They may be dirty and off balance or possibly rubbing.
Post# 431517 , Reply# 5   9/9/2020 at 03:10 (1,315 days old) by RoyalFan103 (Washington)
It stopped doing that Chewbacca noise after I lubed the top bushing shortly before I joined Vacuumland last year.
Post# 431558 , Reply# 6   9/9/2020 at 18:15 (1,314 days old) by huskyvacs (Gnaw Bone, Indiana)
No 3 in 1 Oil. That oil is SAE20 at most and some formulas are less than that, not for heavy duty applications like vacuum motors. Also 3-in-1 oil contains detergent and once the lubricating oil burns away the detergents are left behind to attract and hold dust and dirt. In a sewing machine this is likely not much of a problem, but in a vacuum cleaner it's a big deal.
Use a non-detergent SAE-30 electric motor oil when needed, and for situations where grease packing is required, Mobil Polyrex EM. Also leave the vacuum to sit for 3-4 hours after oiling to allow the oil to soak in and settle itself.
I got mine at Walmart: www.walmart.com/ip/Super-...
Non-detergent motor oil is typically recommended for lubricating electric motors that do not have sealed bearings and for lubricating bronze sleeve bearings. Non-detergent is usually specified in electric motor manuals - even for modern electric motors. This is why Royal and TTI use it because their vacuums are marketed mainly for industrial use and are used for hours upon hours a day, nearly non-stop. You need to use a slightly heavier oil so it doesn't burn up with friction.
Post# 431570 , Reply# 7   9/9/2020 at 23:41 (1,314 days old) by broomvac (N/A)
@huskyvacs
3-in-1 Electric Motor oil is non-detergent, and that’s specifically why I recommend it. See product FAQs.
SAE 20 weight is not blanketly inferior to SAE 30. Higher speed applications usually want a lower weight as too high of a viscosity can lead to oil overheating. Vac motors qualify as high speed.
CLICK HERE TO GO TO broomvac's LINK
Post# 431575 , Reply# 8   9/10/2020 at 01:28 (1,314 days old) by EurekaFanSquid (Sacramento, California)
eurekafansquid's profile picture
shopl vacd is vetgsry goojkljd
i tr;yi;l;j
it very godsjfl
Post# 431577 , Reply# 9   9/10/2020 at 05:12 (1,314 days old) by RoyalFan103 (Washington)
I do have 3 in 1 Electric motor oil. I've used that on the sleeve bearing a year ago before I joined this site.
