Thread Number: 40588
Sanitronic 7 mods |
Post# 431245   9/4/2020 at 15:42 (1,301 days old) by calv (Indianapolis, IN)   |   | |
Hi! I’m new and I’ve caught the vintage vacuum bug. Picked up a Sanitronic 7 and a Hoover/Eureka convertible together for 1 whole dollar at an estate sale. Both work and in decent condition! My focus currently is the Sanitronic 7. I love it. Wondering if there are ways to refine/clean/upgrade motor to get extra power/suction. If not, cool. If so, curious. Also wondering if anyone has come up with an insert for the bag. I’ve got a lot of old built up dust and thorough inversion and light water cleaning is soon to happen but I’m wondering if anyone has come up with a way to retrofit any kind of HEPA filter or anything more modern to aid it’s cleaning. Looking forward to hearing from this community!
Post# 431248 , Reply# 1   9/4/2020 at 17:01 (1,301 days old) by Hmc1981 (St. Augustine, Florida)   |   | |
And, nice S7!
As for any power modifications, I can’t say that there are any, but maybe others on here will know of something - but I’ve never heard of any. As far as the bag. There have been some topics on here in the past about HEPA conversions, I’d search archives... One thing that I have done, and it’s far from HEPA filtration—- is after cleaning the bag and vacuuming out all the dirt and debris (inside and out), before reinstalling, I put a stocking (not too thick, not too thin) over the emtor opening and then install the bag over that. The stocking will help keep the inner walls of the bag dust free, and in my experience makes a fairly decent difference as far as filtration. The stockings are fairly cheap so, once they fill, remove and replace with a new one. Another way (to keep from having to remove the bag each time is to install the stocking in the front opening of the emtor - where it connects to the exhaust on the machine - and be sure to fit the o-ring over it so it keeps a nice seal. The downside to that setup is that you have to replace more frequently, as if it gets too full, it won’t pull out from the smaller front opening. That’s just a “rig it and run” way of doing it, but it does make a difference. You can always install a fill tube on the top emtor opening (search archives) and have a zipper installed on the bag to function like newer machines - but then you will be altering an original bag. In any case, I hope this information helps, or at least gives some inspiration to a whole new idea. Welcome and hope you enjoy the site! |
Post# 431251 , Reply# 2   9/4/2020 at 18:19 (1,301 days old) by calv (Indianapolis, IN)   |   | |
Post# 431256 , Reply# 3   9/4/2020 at 20:18 (1,301 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
The only modification I can think of would be to use the motor group from a Dual Sanitronic 50 and 80, and its speed switch. You would also have to route the wires to both the foot switch and speed switch correctly.
If you do undertake this, please note the newer field coil used on the D80 since June 1968 will not adapt to the older foot switch as used on your Sanitronic VII. ~Ben
Post# 431296 , Reply# 5   9/5/2020 at 10:39 (1,300 days old) by human (Pines of Carolina)   |   | |
I have no idea if it would work for your machine but you could try replacing the entire emptor and bag assembly with one off of a Heritage/Legend series machine (Heritage, Heritage II, Heritage II Legend, Legend II). If the diameter and bayonet lugs on the motor exhaust are the same as yours, you're in business. I did this on a Heritage 1HD I got earlier this year. I replaced the original dump bag setup with the corresponding filter bag assembly off of a Heritage II and then later replaced the gray H2 outer bag with the appropriate orange one for the Heritage. I've also read in this forum about a conversion that uses Eureka F&G style bags but if I recall correctly, that setup is somewhat less efficient and apparently loses a bit of suction. Either way, I don't blame you for wanting to get rid of the dump bag.
Post# 431305 , Reply# 7   9/5/2020 at 13:03 (1,300 days old) by kirby519 (Wisconsin)   |   | |
The Heritage II Legend II Mini emptor boot will fit that machine. |
Post# 431341 , Reply# 8   9/5/2020 at 22:55 (1,300 days old) by Lesinutah (Utah)   |   | |
Hey
Did you get my email? The emtors from the 516 (1956)-heritage 2 legend 2. If you get a 2.5" of pc pipe, 2 45 degree fittings. You can put that right inside the exhaust and behind bag emtors connector. Then you could Use f&g setup. I.have tried this and it works well. The reason the f&g setup with no emtor .is bad because it restricts airflow. The emtor provides throttle needed. Les |
Post# 431651 , Reply# 9   9/11/2020 at 20:18 (1,294 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
