Thread Number: 40551
Eureka 2095 A |
Post# 430719   8/26/2020 at 21:22 (1,336 days old) by Lesinutah (Utah)   |   | |
I'm getting this vacuum I got off eBay.
It's a cordaway with a hi and low speed. It will need cleaned up but I've seen much worse. It has a 3.5 blender motor and hi and low speed. If I put a sanitaire 7 amp motor in it would it negate the hi and low speed. I was wondering because it could be cool is for a 3.5 amp motor. Info in the vac would be appreciated. Led |
Post# 430720 , Reply# 1   8/26/2020 at 21:24 (1,336 days old) by electroluxxxx (……)   |   | |
Unless the motor is a dual speed motor I don’t think it can be done. I’d leave it original and congrats on the purchase! |
Post# 430722 , Reply# 3   8/26/2020 at 21:37 (1,336 days old) by Lesinutah (Utah)   |   | |
Post# 430730 , Reply# 4   8/26/2020 at 22:29 (1,336 days old) by electroluxxxx (……)   |   | |
You might actually like that 3.5 amp motor. If I’m not mistaken those actually had a decent amount of power for what they were, I believe it is a pancake motor. |
Post# 430789 , Reply# 5   8/27/2020 at 18:08 (1,335 days old) by eurekaprince (Montreal, Canada)   |   | |
Eureka uprights with the “Power Touch” handle have a three-setting switch: low power, high power and “attachments”. The first two settings use the power touch button on the underside of the handle. The “attachment” setting is an “always on” setting when using the optional above-the-floor attachments, or if you want to have the motor always on while vacuuming carpets. The setting uses the high motor speed. I always thought the feature was cool - if you need to pause your vacuuming to move a piece of furniture or to answer the phone, you just let go of the handle and voila - the machine turns off.
Post# 430791 , Reply# 6   8/27/2020 at 18:09 (1,335 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 430794 , Reply# 7   8/27/2020 at 19:17 (1,335 days old) by Lesinutah (Utah)   |   | |
