Thread Number: 40409
Kirby Legend II missing rivet latch assembly for rug plate? |
Post# 429045 , Reply# 1   7/25/2020 at 18:54 (1,362 days old) by TURBO_360 (North Texas)   |   | |
Post# 429049 , Reply# 2   7/25/2020 at 19:45 (1,362 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Amanda,
What you have is the very rare 13" wide nozzle for your machine, and as you have stated it does not have the twist-lock latches but the old-style hinges. So, nothing is missing on this. These were the parts used: 140869 - nozzle bumper rivet 144088 - belt lifter body casting, maroon 144181 - belt lifter spring washer 144281 - belt lifter hook 144681 - belt lifter flat washer 144781 - belt lifter assembly screw 145481 - belt lifter cap bearing 146388 - belt lifter label (top) 146684 - belt lifter instruction label 146788 - belt lifter label (bottom) 147988 - nozzle bumper, 13", maroon 154169 - brush roll adjusting screw 154456S - rug plate assembly w/gasket 1545 - rug plate hinge rivet 1547 - rug plate hinge 1548 - rug plate gasket 155281 - brush thread guard 301282 - belt (use 301289 or 301291) 500505 - brush roll assembly (NLA) I have a similar 13" nozzle for my Heritage II. The newer bare-wood brush rolls will have color-coded end caps to help you understand which side goes where: the black cap end is the larger of the two ends, and the white cap end is the smaller one. Here is a video of David Greer's Legend II with the 13" nozzle in action: ~Ben This post was last edited 07/25/2020 at 20:24 |
