Thread Number: 40159
Worst hose you've ever used |
Post# 426404   6/2/2020 at 17:25 (1,422 days old) by niclonnic (Bonney Lake, WA)   |   | |
What is the worst-designed hose you've ever used on an upright vacuum cleaner?
For me, it's on the Bissell Pet Hair Eraser Lift-Off vacuum. I've owned this machine since Christmas of 2018, and it's pretty much been my daily driver. While it's a fine vacuum, the hose is just too short, making it very awkward to use. It gets stiff while using the crevice tool or turbo brush, which in turn makes the vacuum tip over constantly, even in "Lift-Off" mode (due to the hose being mounted up high). This turns a stair cleaning job into a balancing act. In addition, the hose does NOT stay locked on to the vacuum; Bissell stupidly did not include a locking mechanism for the hose, meaning there is no audible click when you turn the hose cuff clockwise to "lock" it into place. So while using the hose, it has a tendency to detach completely from the vacuum, forcing me to reattach it often. This happened to my sister while she was vacuuming earlier today. She called me into her room, where I then reattached the hose for her. The other poorly designed part of the vacuum is the telescopic wand; it's short and does NOT stay locked, so it constantly retracts while cleaning, even after turning the collar to the "lock" position as tightly as I can. This is especially irritating when using the crevice tool. I will say that my Dyson DC07 Animal has a superb attachment system. Its hose and wand (not telescopic) are significantly longer, making them a lot more usable than on the Bissell. Every vacuum cleaner has its faults, but the hose on this Bissell is just infuriating to use. Thoughts? |
Post# 426414 , Reply# 2   6/2/2020 at 20:36 (1,422 days old) by fan-of-fans (USA)   |   | |
Worst upright hose I remember was my mom's old Kenmore Quick Clean bagless upright. Every time I would try to use the hose, as soon as you put the crevice tool on or put on the dusting brush and touched it to a surface, the hose would spring back and tip the machine over. A few times it fell over on me and it hurt!
I will say my Kenmore Progressive upright has a better designed hose as far as that, it has a clip at the bottom that keeps it from falling over, and I've never had it tip. Also it has three speed vs just one so that helps. My Electrolux has a very stiff woven hose that just seems very short. I can't fault it simply because it was probably less stiff when it was new, it's just age. Not a big fan of the hose end on my Kenmore Progressive canister. As mentioned above, the hose end is so big, especially with the third gen models. That horse hoof dusting brush just gets in the way. I did order a dusting brush from the newer Kenmore Elite canisters which fits and is more like the older dusting brushes, so that helps a lot. |
Post# 426415 , Reply# 3   6/2/2020 at 20:48 (1,422 days old) by myles_v (Fredericksburg, VA)   |   | |
Post# 426428 , Reply# 4   6/3/2020 at 08:27 (1,422 days old) by suckolux (Yuba City, CA)   |   | |
Post# 426439 , Reply# 5   6/3/2020 at 12:07 (1,421 days old) by dysonman1 (the county)   |   | |
Post# 426441 , Reply# 6   6/3/2020 at 13:14 (1,421 days old) by human (Pines of Carolina)   |   | |
The absolute worst hose was the non-powered woven hose that came with the Electrolux 1205 that my dad grabbed from a neighbor's trash pile in the early '80s. The thing leaked so badly it effectively had no suction. I didn't know about woven hoses back then and wasn't at all a 'vacuphile' like I am now, so it never occurred to me that the problem was with the deteriorating structure of the hose. Given its lackluster performance, I was amazed to find it languishing in my parents' attic in 2016 almost as amazed at how well the machine worked after sitting forgotten for at least 20. A good, OEM vinyl electric hose makes a world of difference.
Another bad hose is the 10-foot lightweight plastic hose I got for my Electrolux Discovery Plus. The machine is essentially a Discovery II with brackets for onboard tool storage. The having the tools onboard during use is more than a little awkward and the hose constantly pulls the machine over. I understand from some rather knowledgeable folks on this site that the machine would have shipped with a six-foot hose, which might be more manageable. If and when I pull that machine out of back of my barn, where it has sat in what one might euphemistically call 'deep storage' for three or four years, I might consider cutting that hose off to a more correct length. |
Post# 426443 , Reply# 7   6/3/2020 at 13:35 (1,421 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Hoover's "veriflex". tons of it are still working well.
Hoover's "ultraflex" works si ell, too. Hoover's "Tufflex" is about the best. Hoover's 'pool filter' is "lackluster". It's found on lots of the plastic stuff. The hose on the Connies would cut near the wand, from lots of use. Luckily, it can be cut off and reattached. Never had an issue with any of my cleaning tools. The cleaners always follow me around the house. |
Post# 426444 , Reply# 8   6/3/2020 at 13:36 (1,421 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 426447 , Reply# 9   6/3/2020 at 13:53 (1,421 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 426448 , Reply# 10   6/3/2020 at 14:15 (1,421 days old) by niclonnic (Bonney Lake, WA)   |   | |
Jon requested some pictures of my Bissell, so here they are. The hose IS pretty stretchy, just not long enough for my taste.
Post# 426475 , Reply# 12   6/4/2020 at 12:08 (1,420 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
I hate the Shop Vacs that have the huge diameter clunky hose. Trying to clean anything other than perhaps an aircraft hanger with it is a nightmare. You constantly have to wrestle it around, it can swing up and hit you in the face if you try and turn the tools around, it collects static electricity and everything sticks to it and then rubs off the debris where you just cleaned. The ones with the normal size hose are better.
Post# 426476 , Reply# 13   6/4/2020 at 13:17 (1,420 days old) by human (Pines of Carolina)   |   | |
I agree the large diameter shop vac hoses are ungainly but they do have their uses, especially for picking up large, chunky debris. I once took up an oak parquet floor and collected the parquet pieces with such a shop vac. It was much easier than doing it by hand. My (now-ex) wife taught third grade and took a bunch of them to school for educational purposes.
Post# 426479 , Reply# 14   6/4/2020 at 13:39 (1,420 days old) by suckolux (Yuba City, CA)   |   | |
Post# 426501 , Reply# 16   6/5/2020 at 03:01 (1,420 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Yup the large dia. hoses are good if you're doing that kind of work, but when they sell normal Shop Vacs with those big hoses it becomes rather ungainly. The vac I bought last came with a big hose, I didn't realize it at the time as it didn't look that big on the box.
I found a smaller little one of the newer chrome Shop Vacs on eBay for cheap and it has a normal sized hose on it, and its a lot better as a little around the house runabout. I use it in my basement to clean up yucky basement debris like old mouse droppings in the ceiling and spiders and dead bugs and cat litter and such I don't want stinking up my good upstairs vac. |
Post# 426546 , Reply# 17   6/6/2020 at 01:27 (1,419 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
who wanted to paint a brick blue to match his Convertible w/ front tools. He complained of tipping....wanted to attach the brick to prevent tipping. but ran the vac everyday.
I told him he used the wrong technique. He simply didn't know how to use his apparatus correctly. He also collected Dormeyer mixers. They were everywhere. |
Post# 426569 , Reply# 18   6/6/2020 at 13:59 (1,418 days old) by niclonnic (Bonney Lake, WA)   |   | |
I own a Ridgid 12-gallon shop vacuum that has a large diameter hose. It is a little unwieldy to use and it and gets staticky on the outside, but it allows for a large cleaning radius.
Also, I shouldn't have said "upright" in my OP, as now we're talking about canisters and Shop-Vacs in addition to uprights. Just a little mistake on my part. |
Post# 426604 , Reply# 19   6/7/2020 at 09:11 (1,418 days old) by broomvac (N/A)   |   | |
For me, this hose takes the cake.
Post# 426605 , Reply# 20   6/7/2020 at 09:50 (1,418 days old) by RainbowD4C (Saint Joseph, Michigan )   |   | |
When I worked at the ad agency I was cleaning and rearranging my office. At the time they had a Bissell Powerforce with a stretch hose. I was trying to dust the top shelf of a bookcase and I had the hose stretched out to the farthest. My boss came in and scared me and I lost my footing on the stool I was on and let go of the hose which in turn came back and the handle caught me under the eye and cracked my cheek bone.
The only decent stretch hoses are the Shark hoses used for the Shark Powered line. They are really easy and nice to use. |
Post# 426664 , Reply# 21   6/8/2020 at 02:20 (1,417 days old) by tolivac (Greenville,NC)   |   | |
Have the same DD cleaner-the hose is USELESS!!!!!You can generate more suction by inhaling!The hose that fit into the front of the machine was better-even if you had to take the brush belt off the motor. |
Post# 426669 , Reply# 22   6/8/2020 at 11:37 (1,417 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 426676 , Reply# 23   6/8/2020 at 18:30 (1,416 days old) by niclonnic (Bonney Lake, WA)   |   | |
I found out that the hose on my Bissell DOES includes a locking mechanism!!! I took the hose off and looked at the vacuum inlet, and there ARE slots and tabs on the inlet and hose collar, respectively. I turned the hose collar clockwise, this time with some force, and it locked in place! Now the hose won't detach anymore! But I still have the bad telescopic wand to deal with. I can't believe it took me a year and a half to find out that the hose locks on! I'm so relieved!!!
Post# 426680 , Reply# 24   6/8/2020 at 23:58 (1,416 days old) by panasonicvac (Northern Utah)   |   | |
Post# 426681 , Reply# 25   6/9/2020 at 00:11 (1,416 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 426695 , Reply# 26   6/9/2020 at 11:09 (1,416 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 426763 , Reply# 29   6/10/2020 at 16:12 (1,414 days old) by niclonnic (Bonney Lake, WA)   |   | |
Post# 426843 , Reply# 30   6/12/2020 at 00:10 (1,413 days old) by panasonicvac (Northern Utah)   |   | |
