Thread Number: 40054
BVC TURBINET 3 |
Post# 425176   5/9/2020 at 21:16 (1,446 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
Hey guys, does anybody know how to take apart a BVC TURBINET three? As currently the electrical cord is coming out of the blower port and I’m not entirely fond of that as it prevents use of the blower port, this is about as far as I’ve gotten and I’m not sure where to continue from here I have not taken apart anything internally
Post# 425178 , Reply# 1   5/9/2020 at 21:42 (1,446 days old) by Lesinutah (Utah)   |   | |
If you look at the pic it has 1 & 2.
1 is taking off the top bolt or screw. It will seperate on the line shown. This should make top half of the motor. 2 is other screws that might attach lower housing and bearing and a fan. Les
Post# 425181 , Reply# 2   5/9/2020 at 22:04 (1,446 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
I’ll give that a try and what are the bolts for number two?Is it these 3
Post# 425183 , Reply# 3   5/9/2020 at 22:11 (1,446 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
In the image below at the back of the bearing there is grease coming out is that a bad thing?
Post# 425186 , Reply# 4   5/9/2020 at 22:42 (1,446 days old) by Lesinutah (Utah)   |   | |
Post# 425188 , Reply# 5   5/9/2020 at 22:46 (1,446 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
And I do not think it’s going well, as it’s not separating from where I wanted it to separate it separating from in between there
Post# 425189 , Reply# 6   5/9/2020 at 22:50 (1,446 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
Post# 425199 , Reply# 7   5/10/2020 at 02:03 (1,446 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 425206 , Reply# 8   5/10/2020 at 04:07 (1,446 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
Although all I’m trying to do is to change the cord from where it’s coming out of has I’ve always had issues with it coming out of the blower port, Although I have a feeling it is not one large casing, as you can see there is a small gap Where the motor housing meets the last separator for the last fan stage
Post# 425209 , Reply# 9   5/10/2020 at 10:38 (1,445 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
Bad news, on one motor wire the insolation has crumbled, the other one appears to Be protected with a PVC sheath that was already on the motor The one in yellow is the one that’s protected by the PVC sheet the other one is the one that would need to be replaced
Post# 425474 , Reply# 10   5/14/2020 at 20:38 (1,441 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
And now the cord is coming out where I’d like it to
Post# 425475 , Reply# 11   5/14/2020 at 20:40 (1,441 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
Post# 425490 , Reply# 12   5/14/2020 at 23:09 (1,441 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 425494 , Reply# 13   5/15/2020 at 02:06 (1,441 days old) by Adam-aussie-vac ( Canberra, Australia )   |   | |
Post# 425555 , Reply# 14   5/16/2020 at 03:42 (1,440 days old) by MadMan (Chicago, IL, USA)   |   | |
