Thread Number: 40031
Aerus/Electrolux 80th Anniversary Ultralux |
Post# 424921   5/5/2020 at 20:44 (1,448 days old) by ridgidwd0670 (se wood co ohio)   |   | |
can I upgrade to a two-stage motor? I'm not too fond of single stage motor
Also how do I rewire the PN receptacle so the PN doesn't stay on when the vac is turned off The bag & exhaust filter smell like stinky feet so I threw the bag & filter away because they were petrified too pic of inside the Ultralux with single stage motor
Post# 424925 , Reply# 1   5/5/2020 at 21:20 (1,448 days old) by human (Pines of Carolina)   |   | |
I don't know the answer to the first question but if you can find a two-stage motor that will physically fit into the shell, I don't see any reason it wouldn't work.
As far as the power nozzle is concerned, you probably have a couple of wires reversed coming off the cord winder. I had a similar situation with my Silverado last year when I reconnected some wires and ended up reversing two. In that case, the power nozzle would run when the vacuum was shut off but when the vacuum was running, the power nozzle would shut off. That was when I learned to photograph things with my phone before taking them apart. |
Post# 424926 , Reply# 2   5/5/2020 at 21:26 (1,448 days old) by Lesinutah (Utah)   |   | |
You need to know what type of motor is in the machine. I'm going to take a guess it's a 5.7" motor that is/was in c9 compact, filter queen 360,I think it's a 7.5 amp motor. It probably pulls 100-110 CFM.
If I assumed correctly ametek lamb site. There is a 2 stage from red tristar, proteam and a few others. If you can find the 2 stage motor that proteam uses puts out 150 CFM I'm not sure on the amps but between 9-12. People are going to pop up saying don't modify it. It's not made for that motor etc. Once you find the motor get it off eBay it's slot cheaper. Les |
Post# 424928 , Reply# 3   5/5/2020 at 21:42 (1,448 days old) by Lesinutah (Utah)   |   | |
It's not connected to the switch.
Follow it to where all the wire nuts are. Motor black white Cord black white Switch black white Pn black white (you can flip them if from black to white. I don't recall exact wiring. But if you look up compact wiring dysonman tells how to wire it with three connectors. Les |
Post# 424931 , Reply# 4   5/5/2020 at 22:51 (1,448 days old) by kloveland (Tulsa)   |   | |
That looks like the VM3 motor. Hope I said this correctly. This already has more power than the previous models. I know some of those came with the dri-lux (similar to the capture carpet cleaning system) that's why the PN stayed on when the canister switch was turned off. To run the dri-lux PN. Those were sold with two PNs. The normal power nozzle and the dri-lux.
The vacuum is not wired wrong. It was designed that way. I had one myself a couple of years ago. CLICK HERE TO GO TO kloveland's LINK |
Post# 424946 , Reply# 5   5/6/2020 at 08:36 (1,448 days old) by human (Pines of Carolina)   |   | |
If the power to the power nozzle is straight wired from the machine, that explains why they put an on/off switch on the power nozzle, although I would think it more convenient to have a switch on the hose handle like some aftermarket ones do. My Diamond J came with that type of hose and I find it very convenient to be able to instantly turn the power nozzle off if it catches something it shouldn't. My Diplomat LX has switches both on the aftermarket hose and the power nozzle. The first time I tried it out, it was very confusing getting all the switches turned on to fire up the power nozzle.
Post# 425003 , Reply# 7   5/6/2020 at 22:23 (1,447 days old) by suckolux (Yuba City, CA)   |   | |
Post# 425042 , Reply# 8   5/7/2020 at 16:28 (1,446 days old) by Jo (Dallas,TX)   |   | |
Ha, who knew it was as simple as that! One would think two fans would be better than one as the motor would runaway a lower rpm. Jon |
Post# 425044 , Reply# 9   5/7/2020 at 17:02 (1,446 days old) by Blackheart (North Dakota)   |   | |
It seems like the more stages you have the higher the suction (waterlift) you get but you often do sacrifice airflow. When you have multiple fans you typically have a stationary layer between the fans which makes it's airpath a little more complex.
Going back to the original topic at hand. I'm not entirely sure here but I think you may need to swap the plastic motor casing to accomplish this. Older plastic bodied machines like the 2100 and 6500 did both use dual stage motors. I don't think the outer body has changed but it would be logical to assume that they changed the motor casing to fill in the the space created by the shorter fan case. If you watch this video you'll see the inside of the 6500 which used a dual stage. |
Post# 425380 , Reply# 10   5/13/2020 at 17:01 (1,440 days old) by ridgidwd0670 (se wood co ohio)   |   | |
I cleaned & reassembled the vac but the 'Power' indicator lite & PN aren't working; but at least the vac still turns ON & OFF like normal
I don't know if I got a electrified hose with bad electrical current/no current? Its a used genuine Electrolux coiled vinyl hose; but the machine end coupling's seal is warped. Other than those 3 issues everything else works great I'm using V A C HEPA bags but no exhaust filter because I am waiting for the filters & dusting brush bristle inserts to arrive (the small combo tool's bristles have 'thinned out' but rubber 'donut' still intact |
