Thread Number: 39933
VacuMaid Central Vacuum Inlet Valve Mounting Bracket |
Post# 423901   4/21/2020 at 20:07 (1,458 days old) by mmcphee (Lisbon Falls, Maine)   |   | |
Hi Everyone,
Just wanted to get some group knowledge. I got a VacuMaid Central Vacuum Inlet Valve and the mounting holes do not line up to mount onto the standard plastic central vacuum inlet valve mounting bracket. I was wondering if anyone might know of where to find the correct mounting plate so I can use it. |
Post# 423907 , Reply# 2   4/21/2020 at 20:38 (1,458 days old) by Compactelectra (Palm Springs)   |   | |
From MD Manufacturing. I have the ones in bronze. Remind me of vintage Filtex inlets and work with current low voltage hoses.
builtinvacuum.com/parts/all/outl... |
Post# 423911 , Reply# 3   4/21/2020 at 20:43 (1,458 days old) by vacman1961 (North Babylon, New York)   |   | |
This is a VacuMaid valve.
Post# 423912 , Reply# 4   4/21/2020 at 20:46 (1,458 days old) by vacman1961 (North Babylon, New York)   |   | |
Those MD inlets are cheap replacement valves, they used to be manufactured by Beam and were a universal valve. The Original VacuMaid valve is quality. I personally like original VacuFlo valves, thats what I have installed in my home. |
Post# 423925 , Reply# 6   4/21/2020 at 21:39 (1,458 days old) by Compactelectra (Palm Springs)   |   | |
Post# 423951 , Reply# 8   4/22/2020 at 02:37 (1,458 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 423994 , Reply# 10   4/22/2020 at 20:27 (1,457 days old) by Compactelectra (Palm Springs)   |   | |
I agree about the durability of these inlets. I had 12 of them in my system in Chicago for 15 years used by housekeepers and never had a problem. What I like is that they remind me of the vintage Filtex inlets without the buttons and lights. And once you get used to the low voltage switch on the end of the hose, you’ll never go back.
Post# 424036 , Reply# 11   4/23/2020 at 07:31 (1,457 days old) by mmcphee (Lisbon Falls, Maine)   |   | |
Thank you for your comments on the inlet. Before I can even get to installing it, I have to solder a wire onto it for the low voltage. When I received the inlet, It had no wires on it at all. I managed to get the wire for the pin jack from an automotive lightbulb holder that I bought at NAPA and it works perfectly. I tried to solder the wire onto the neck but I couldn't get it to work since it was my very first attempt at soldering anything and I burned my finger in the process. I had an idea about using a metal mounting plate and maybe that will work.
Post# 424911 , Reply# 13   5/5/2020 at 17:36 (1,444 days old) by mmcphee (Lisbon Falls, Maine)   |   | |
Since I actually have the Lexan inlet hooked up to my Model 26, I will certainly forgive the omission! I did get some screws for my inlet and they do go in at an angle but it should work. I had my local vacuum repair shop solder the wire on (didn't want to burn my finger again) so it should hopefully work.
Do you happen to know what style of inlet would have been installed when the Model 26 was for sale? Matt |
