Thread Number: 39927
Replace hose end Compact C9 |
Post# 423848   4/20/2020 at 20:54 (1,438 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
I use my vintage iec comapct electra model C9 every day almost if not more , so im needing to replace the hose that attacht to the handle im speaking of the metal tube that inserts in the wand i lsot the button lock last month a lil tape coveres the holes .Is there a way to repalce the handle metal tube only ???
Post# 423850 , Reply# 1   4/20/2020 at 21:26 (1,438 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 423856 , Reply# 2   4/21/2020 at 00:00 (1,438 days old) by Lesinutah (Utah)   |   | |
Wow you do exist. One of the people on here I like.
If you make sure there is no electrical connections in the handle where the metal is covered. You get a blow dryer or a heat gun and heat along where the metal is. When it's hot channel locks or crescent wrench with a towel or hot pad so you don't scratch up the metal. The heated area would loosen any glue and or loosen it where twisting it. It would come loose where you can pull it out. Les |
Post# 423875 , Reply# 3   4/21/2020 at 10:23 (1,437 days old) by dysonman1 (the county)   |   | |
Post# 423880 , Reply# 4   4/21/2020 at 13:07 (1,437 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 423885 , Reply# 5   4/21/2020 at 14:27 (1,437 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 423914 , Reply# 6   4/21/2020 at 20:55 (1,437 days old) by vacman1961 (North Babylon, New York)   |   | |
Just order these, this should help you out. See if your local vacuum store carries them. CLICK HERE TO GO TO vacman1961's LINK |
Post# 423916 , Reply# 7   4/21/2020 at 20:58 (1,437 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 423934 , Reply# 8   4/21/2020 at 22:48 (1,437 days old) by Lesinutah (Utah)   |   | |
Here is a pic.
I have atleast 3 rainbow sets of wands. I have them in a tote. My waterbed spring a leak and is on top of the totes. I took a pic of the button you maybe referring to. I don't have a gas handle for my compacts. If I wanted that off. There is a screw somewhere holding it together. I imagine 4 screws to be exact. Undo those . Www.rainvac.com or www.ezvacuum.com...
Post# 423968 , Reply# 9   4/22/2020 at 14:10 (1,436 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 423987 , Reply# 10   4/22/2020 at 19:38 (1,436 days old) by Lesinutah (Utah)   |   | |
Post# 423989 , Reply# 11   4/22/2020 at 19:45 (1,436 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
I know there is a screw you can remoove on the handle might be able to ordera new stub tube and replace that part any one care to chime in i welcome the help ty .
My compact c9 is no musem peice , she is work hard long and often asa vacuum is a tool to help me clean.I did poor money time and ressources into fixing her and she pulls the paint off the walls now if i could fix my handel id be so happy do understand my c9 is a work horse yet vintage whit NOS part .I hope every one understand u i use my vintage vac alot ty . |
Post# 423991 , Reply# 12   4/22/2020 at 19:48 (1,436 days old) by Lesinutah (Utah)   |   | |
Post# 424063 , Reply# 13   4/23/2020 at 14:34 (1,435 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 424073 , Reply# 14   4/23/2020 at 16:58 (1,435 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 424235 , Reply# 15   4/25/2020 at 15:51 (1,433 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 424242 , Reply# 16   4/25/2020 at 17:30 (1,433 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Change the handle shes fix.
Post# 424339 , Reply# 17   4/27/2020 at 12:51 (1,431 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 424386 , Reply# 18   4/28/2020 at 15:41 (1,430 days old) by Lesinutah (Utah)   |   | |
I didn't notice you replied back.
Yes I have cxl, c9, c8 and a patriot. The c8 with the new motor has the most power. Tge cxl motor was replaced in mid 2000's. The c9 I'm not sure but none are lacking in power. The Patriot has a patriot version of the wessell werk 340. I love wessell week's but omg I don't like it. If you get a rug snagged in the brush roll you have put nozzle in locked upright position. You press the there.al reset button and power on and off the machine. It's pulling 90 plus cfms so the rugs are going to get stuck. The machine doesn't perform as well as TriStar/compacts as you know to have the blue patriot storm bags. I have tried a type c cannister bag and it works better. I just don't like the power nozzle. This is off topic on YouTube you have your big shopvac and you used an electric power nozzle on it. How did you do this. I used my big Craftsman shopvac. I have a good filter and put disposable bags on it. They are very large bags. It has I. Guessing 120 or more CFM. Les |
Post# 424387 , Reply# 19   4/28/2020 at 16:11 (1,430 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
