Thread Number: 39879
Columbus Sylvia and attachemts |
Post# 423295   4/12/2020 at 17:18 (1,467 days old) by gsheen (Cape Town South Africa)   |   | |
So this is the second machine I got from the same lady, this one a upright with brand new attachments.
The base was severely yellowed and the fan mad a noise when it ran, the bearings were also shot. The cord too was a little short for my liking :) |
Post# 423296 , Reply# 1   4/12/2020 at 17:24 (1,467 days old) by gsheen (Cape Town South Africa)   |   | |
The motor was stripped, new 608 bearings fitted.
You cant get the belts for these machines anymore so I used the large belt from a dyson dc14 clutch. Worked a treat |
Post# 423297 , Reply# 2   4/12/2020 at 17:28 (1,467 days old) by gsheen (Cape Town South Africa)   |   | |
I sanded the base and buffed it up to a high gloss agian.
Post# 423298 , Reply# 3   4/12/2020 at 17:30 (1,467 days old) by gsheen (Cape Town South Africa)   |   | |
The attachments are new, the extention tubes are very long, longer than any I have found before, much longer than any on modern day vacuums that still use two separate tubes.
The hose is also very long for a upright vacuum, especially a budget one like this one |
Post# 423299 , Reply# 4   4/12/2020 at 17:38 (1,467 days old) by gsheen (Cape Town South Africa)   |   | |
Their are two base plate covers that clip over the base plate of the machine, one is obviously for hard floor vacuuming as it has a felt strip( that fell off and I forgot to add it back for the pic ) it also fearures the lever to activate the higher wattage button like the converter plate.
The other plate has a odd extra side piece on one side and little pins and a very narrow opening but does not have the lever to operate the higher suction. The instructions have no info on the tool usage |
Post# 423300 , Reply# 5   4/12/2020 at 17:41 (1,467 days old) by gsheen (Cape Town South Africa)   |   | |
All hooked up, the only issue is the machine is very light and you can easily tip the machine over when just moving the hose slightly
Post# 423321 , Reply# 6   4/12/2020 at 22:41 (1,467 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 423325 , Reply# 7   4/13/2020 at 00:44 (1,467 days old) by tolivac (Greenville,NC)   |   | |
Interesting little vacuum and attachments-like the idea of the pigtail cord-you can then get a cord as long or short as you need.Does this use disposable bags? or is it a dump bag? |
Post# 423332 , Reply# 8   4/13/2020 at 03:04 (1,467 days old) by gsheen (Cape Town South Africa)   |   | |
Post# 423342 , Reply# 9   4/13/2020 at 09:10 (1,467 days old) by crazykirbydude (Lexington, KY)   |   | |
Post# 423359 , Reply# 10   4/13/2020 at 13:11 (1,466 days old) by funvacfan (Canada)   |   | |
