Thread Number: 39846
Maintenance tips needed for my 750w Hoover Purepower |
Post# 423017 , Reply# 1   4/8/2020 at 16:47 (1,449 days old) by Turbomaster1984 (Ripley, Derbyshire)   |   | |
That your over complicating things.
If the Hepa filter says it can be washed it means it can be washed. Replace when it becomes worn if necessary. HEPA filters make very little difference to allergies because other variables matter too. They only signify the air quality exiting the machine and don’t mean your home will be allergen free. Wash it and enjoy using your purepower. |
Post# 423108 , Reply# 2   4/10/2020 at 00:16 (1,448 days old) by Lesinutah (Utah)   |   | |
I remember you got it to clean a small plane. You got it at a thrift store for $8.00.
The filters won't go out very often if you continue using bagged setup. If you want to clean filter use air and blow it off. It's not getting very dirty. The filter would be an issue if it was emptied like a dust bin. Les |
