Thread Number: 39813
Need a measurement on Aerus Electrolux upright hose |
Post# 422691 , Reply# 2   4/3/2020 at 17:19 (1,480 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 422704 , Reply# 4   4/3/2020 at 19:14 (1,480 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
You can see why I need to file the connector on the upright hose compared to the pigtail hose
Removing the cuff all I would need to do is attach the connector aside from grinding down the connector |
Post# 422706 , Reply# 5   4/3/2020 at 19:30 (1,480 days old) by Lesinutah (Utah)   |   | |
I've used quite a few reducers. They have white PVC. You can order online and pick up. They run $1.50.
Post# 422708 , Reply# 6   4/3/2020 at 19:36 (1,480 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
That still leaves the existing issue that the electrical connector is too large to fit into the plug on a G or similar machine. Im going to try and get mine to the bench grinder and gently work away at the rubber to see if i can make it small enough to fit into the connector and still hold tight enough not to pop out.
Post# 422710 , Reply# 7   4/3/2020 at 20:02 (1,480 days old) by Lesinutah (Utah)   |   | |
Post# 422715 , Reply# 8   4/3/2020 at 20:42 (1,480 days old) by luxflairguy (Wilmington, NC)   |   | |
Good luck! |
Post# 422717 , Reply# 10   4/3/2020 at 20:52 (1,480 days old) by Jo (Dallas,TX)   |   | |
Keep in mind both the plug and outlet are rubber so they will give a little so don’t overdo it when downsizing the rubber on the pigtail plug connector. |
Post# 422721 , Reply# 11   4/3/2020 at 21:33 (1,480 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
I have another upright hose, identical bit on better shape than this one. That was why I decided to cannibalize it for the experiment. I wish I took pictures of the process, I had to remove the metal ring and slide the while cuff end apart.
Yes, you're talking to a farm boy here so luckily I've had my share of experience rigging things together...this has just been back burnered several times. Now that I have the proper hose for reference I can try and get this one done. I'll need to find a suitable epoxy for the hose connecotr |
