Thread Number: 39667
Kirby sanitronic question |
Post# 420878   3/1/2020 at 15:59 (1,488 days old) by Bee-Vac (Pomona, Calif)   |   | |
Is this a non-factory rebuild? Sanitronics are not my forte, but I've only seen sanitronics in green. The belt lifter is off of a 560.
Post# 420880 , Reply# 1   3/1/2020 at 16:05 (1,488 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Anthony,
That would indeed be a non-factory rebuild, but rather one by a factory-authorized service center or independent. Going by the fact it was re-trimmed to make it look like a Classic III, I'll say this D80 (if it indeed has the correct two-speed safety switch) was rebuilt in 1978 by that mom-n-pop shop. ~Ben |
Post# 420886 , Reply# 2   3/1/2020 at 17:45 (1,488 days old) by Lesinutah (Utah)   |   | |
The first rule with Kirby is reading the tag. Look for the tag reads Kirby a Scott Fetzer company is important. It is a true vacuum. The label model is what the vacuum is. It's modeled after the Kirby classic 3 model 2cb.
If it has the wide axle and wide wheels it's good thing. The wider axle helps you get all 8 positions on the height adjustor. The d80 with classic 3 axle is the best Kirby ever. I mean suction wise I think it cleans better than any other vacuum and any other Kirby. The vacuum would be trimmed in avacodo green. It's the vacuum on the brave little toaster. Les |
Post# 420898 , Reply# 4   3/1/2020 at 22:57 (1,488 days old) by Lesinutah (Utah)   |   | |
