Thread Number: 39652
AP-100 to be rescued or not |
Post# 420727 , Reply# 1   2/27/2020 at 10:15 (1,491 days old) by luxkid1980 (Richmond, Virginia)   |   | |
Hopefully there was a bag inside. She should have used a wet/dry vacuum for a job like that. Is there evidence that the dust got through the bag (other than the motor sounds bad)? Dusty bag chamber? Did the bag burst open? |
Post# 420729 , Reply# 2   2/27/2020 at 10:34 (1,491 days old) by quebecois (Waterloo, Canada)   |   | |
The bag compartment was cleaned by her. The motor parts are covered with a thin layer of light gray dust, which I assume is graphite dust from the brushes mixed with gyproc dust. I don't think the bag bursted, it is dirty in there, but not much more than usual. |
Post# 420756 , Reply# 3   2/27/2020 at 21:43 (1,490 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 420790 , Reply# 4   2/28/2020 at 13:50 (1,490 days old) by quebecois (Waterloo, Canada)   |   | |
I actually didn't hear it running, I assume all the woman said is true... I went far enough is the disassemblying process to realize that the bearing needs to be replaced, it is pretty loose, I wouldn't be surprised if gyproc dust made its way in the bearing too. |
Post# 420791 , Reply# 5   2/28/2020 at 14:11 (1,490 days old) by quebecois (Waterloo, Canada)   |   | |
Well, that bearing was quite a surprise ! Not because it was shot , but because it is the first time I see one with races in a AP-100 Elux cleaner.
Post# 420799 , Reply# 6   2/28/2020 at 19:57 (1,490 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
That vacuum should have never been used to clean up construction debris. IDK what people think. That dust is very coarse and very fine - so assume it got everywhere. It should have a complete motor disassembly, cleaning, and reassemble. Inspect every part for abrasion and damage and replace.
I have a Kirby that was nearly destroyed in the same way but with drywall debris. It took a lot of work to restore the motor alone nevermind everything else on the vacuum that got clogged with it. Luckily it was an older model that had a metal fan, so all the coarse debris did to the fan was sandblast it, lol Its oddly more polished than the rest of the vacuum. If it was a plastic fan I'm sure it would have been done for! The motor itself was nearly done for, luckily it must have not been run long after cleaning up the debris to get into the motor too much but the dirt was in the grooves of the armature too. |
Post# 420802 , Reply# 7   2/28/2020 at 21:09 (1,489 days old) by quebecois (Waterloo, Canada)   |   | |
A complete disassembly is pretty much what I have in mind. I installed a new motor bearing earlier today. |
Post# 420807 , Reply# 8   2/28/2020 at 22:41 (1,489 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 420809 , Reply# 9   2/28/2020 at 23:02 (1,489 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 420813 , Reply# 10   2/29/2020 at 04:04 (1,489 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Yeah I wondered if that was normal or not to have the bearing ring have that big of a gap in it. How do they go missing? Do they just gradually wear themselves out and disintegrate?
And yeah I've gotten the old "the motor is making a funny noise" remark before. Turn it on and it sounds like a MD-80 taking off. Yeah that's a 'funny noise' alright! |
Post# 420815 , Reply# 11   2/29/2020 at 05:46 (1,489 days old) by quebecois (Waterloo, Canada)   |   | |
Huskyvac's : I already have a few new bearings on a shelf, this one was a 629. |
Post# 420849 , Reply# 12   3/1/2020 at 01:26 (1,488 days old) by MadMan (Chicago, IL, USA)   |   | |
Either a ball escapes completely out the side, or it (or the race) will chip from a stress fracture or whatever, and the loose tiny chip of extremely hard metal gets rolled around in the bearing and tears everything else up, sometimes including the balls. This happens with gears too, where a tooth will chip and that piece gets crunched between the other gears until it destroys them.
Post# 420854 , Reply# 13   3/1/2020 at 01:58 (1,488 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 420869 , Reply# 14   3/1/2020 at 12:59 (1,488 days old) by quebecois (Waterloo, Canada)   |   | |
Motor is more dirty that it looked at first sight. I gave it a good toothbrushing but it seems it's not enough to clean the windings? Would you suggest I clean them with compressed air only? |
Post# 420874 , Reply# 15   3/1/2020 at 15:18 (1,488 days old) by quebecois (Waterloo, Canada)   |   | |
I decided to replace the top fan, because I realized one of the fins was damaged. I have a used in good condition from a dead motor.
