Thread Number: 39335
Sanitaire SC679J fan chamber depth |
Post# 417295   12/15/2019 at 20:56 (1,592 days old) by broomvac (N/A)   |   | |
Post# 417300 , Reply# 1   12/15/2019 at 23:17 (1,592 days old) by Lesinutah (Utah)   |   | |
The depth of all the sanitairre models are the same.
I asked if a 8.5 amp motor would fit in my sanitaire 667 blue line. It will fit the bigger motor. It will also fit the 5 amp motor. I imagine armature and carbon brushes that are built into motor are different. They don't affect the depth of the motor. If you want to double check me look up your sanitairre and see what fan it takes. Then check the fan of desired motor. That's what sanitairre does is make parts replaceable interchangeable and cheap. Les |
Post# 417353 , Reply# 3   12/17/2019 at 20:47 (1,590 days old) by broomvac (N/A)   |   | |
Post# 417357 , Reply# 4   12/17/2019 at 22:43 (1,590 days old) by Lesinutah (Utah)   |   | |
If you look at a sanitairre. Notice all height width e depths. There the same for quite a while. You can say bigger bearing plate etc. The spindle may be slightly bigger or smaller.
If a spindle is a concern it shouldn't be. Same belt, brush roll same dimensions. It will fit you may have to spend. Couple dollars for a new spindle. Les |
