Thread Number: 39302
can this be fixed? |
Post# 416998   12/6/2019 at 17:10 (1,595 days old) by jrdavis (oklahoma)   |   | |
i believe it had a chain switch a long time ago. i thought i remembered the chain coming off. i decided i wanted to see if i could fix it. i remember taking it to a guy thats worked on these motors like this since 1959(about 15 years ago) he's gone now. i think he robbed me! this is what if found when removing the switch cover
Post# 416999 , Reply# 1   12/6/2019 at 18:07 (1,595 days old) by bikerray (Middle Earth)   |   | |
Post# 417003 , Reply# 2   12/6/2019 at 19:13 (1,595 days old) by jrdavis (oklahoma)   |   | |
Post# 417005 , Reply# 3   12/6/2019 at 19:17 (1,595 days old) by Hoover300 (Kentucky)   |   | |
Post# 417008 , Reply# 4   12/6/2019 at 19:27 (1,595 days old) by jrdavis (oklahoma)   |   | |
Post# 417010 , Reply# 5   12/6/2019 at 20:15 (1,594 days old) by Hoover300 (Kentucky)   |   | |
Post# 417014 , Reply# 6   12/6/2019 at 23:02 (1,594 days old) by jrdavis (oklahoma)   |   | |
the vac chasing? lol i'd like to seen that. i did figure out a temporary switch
Post# 417027 , Reply# 7   12/7/2019 at 17:35 (1,594 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
You can buy replacement pull chain switches. There's many different styles and types, and I'm not sure if they are rated for an electric motor operation.
Here's an example; www.zoro.com/zoro-select-... |
Post# 417029 , Reply# 8   12/7/2019 at 18:33 (1,594 days old) by gregvacs28 (U.S.)   |   | |
One of those touch lamps that has 3 dim settings might give you a deluxe three speed vacuum, right?
Post# 417030 , Reply# 9   12/7/2019 at 20:05 (1,593 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 417036 , Reply# 10   12/7/2019 at 22:33 (1,593 days old) by jrdavis (oklahoma)   |   | |
this was a long time ago- when the switch still saw there maybe the switch no longer worked? anyway, whenever it was wired without the switch it ran. ok-see the metal ball? that would go between the fork and theres a metal bar you step on and that pulls the chain
Post# 417037 , Reply# 11   12/8/2019 at 01:23 (1,593 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
The contacts in the switch are likely just dirty or bent apart, probabaly needs a good cleaning. I'm sure the foot pedal was just a way to make it easier to pul lthe chain, still works without it. I've never even heard of a vacuum that has a pull chain to turn it on, but a lot of the early vacuum cleaners were the wild west - everyone was trying every possible thing to see what worked and what didn't.
Post# 417041 , Reply# 12   12/8/2019 at 08:57 (1,593 days old) by bikerray (Middle Earth)   |   | |
I think the Ohio vacuum also had a pull chain or it was a switch the was triggered by the handle bale.
Huskyvacs - his problem is that the switch is gone Here's a picture of the switch parts for an Ohio from a 1936 Buckeye catalog.
Post# 417048 , Reply# 13   12/8/2019 at 11:52 (1,593 days old) by jrdavis (oklahoma)   |   | |
i found a pic with it when it had a switch. i think what happened was the switch chain broke-therefore it wouldnt work
Post# 417055 , Reply# 14   12/8/2019 at 14:40 (1,593 days old) by MadMan (Chicago, IL, USA)   |   | |
I knew it, that's pretty cool. Honestly, it looks like a totally ordinary pull chain switch. Maybe the length of the chain will need to be adjusted, and a big ball end put on it, but other than that, it looks like a totally ordinary, run of the mill pull chain switch. Go to the lamp parts section of the hardware store and buy one. They may have a couple different types, I would buy one of each and return what you don't need.
Post# 417057 , Reply# 15   12/8/2019 at 17:39 (1,593 days old) by jrdavis (oklahoma)   |   | |
Post# 417059 , Reply# 16   12/8/2019 at 19:45 (1,593 days old) by gregvacs28 (U.S.)   |   | |
Hope you did it outside so the dust could just blow away. |
Post# 417062 , Reply# 17   12/8/2019 at 21:27 (1,592 days old) by jrdavis (oklahoma)   |   | |
