Thread Number: 39114
Henry HVR200A stops starts |
Post# 414986 , Reply# 1   10/16/2019 at 13:37 (1,652 days old) by vacuumdevil (Vacuum Hell )   |   | |
Post# 415087 , Reply# 3   10/19/2019 at 20:34 (1,648 days old) by MadMan (Chicago, IL, USA)   |   | |
Sounds like a broken wire or loose connection to me. I bet if it stops, and you smack it, it will start again. If you've already replaced the mains cord, likely the problem is in the wiring inside the unit. Check all connections for looseness and corrosion.
Unlikely that it's a switch. They usually fail in such a way that they either make contact or don't, not an intermittent connection when switched on. Usually. Also when you are checking the wires, it's good practice to tug on them to test tightness. Open it up, plug it in and turn it on. Wiggle wires here and there and see which wire causes it to turn on or off (it's legit called the 'wiggle test'). |
