Thread Number: 39094
Bissell 9500 Pro Heat 2X Won't Squirt Water In "Tools"? Mode |
Post# 414840 , Reply# 1   10/11/2019 at 13:59 (1,651 days old) by vacuumdevil (Vacuum Hell )   |   | |
Well your business definitely lasted a lot longer than it was intended to. Bissell scent the service center saying the pump was designed to last eight working hours before needing replacement. if I had to point a finger at anything in that machine I would consider replacing the manifold I'd also take the end off of the hose and clean it out usually calcium gets stuck in there.
Good luck to you. |
